adjust ignition timming
End Bringer
Originally posted by SpdRcrChk
So Id....you're saying that the suggestion that people make to retard the timing by approximately 1.5 when usung a larger than a 50 shot of nitrous on our cars would really be pointless?
BOOST JUNKY
Originally posted by Voiceofid
that, i do not have an answer. i don't know everything, afterall
yvette, i believe our cars will adjust the timing of everything else according to the change of cam gears degrees, the adjustible cam gears are so much easier back in the older honda because they have distributor ignition, but now, we have computer controlled coil, the computer controls every aspect of our timing, it will retard and advance it's own timing curve according to the change on the cam gears, i see no point to spent the money on those cam gears, for our cars any way. i don't belive it will yeild anything significant either on the rsx. my instructors said he has seen computerized ignition timing adjust itself a full 200 degrees (back in the distributor days, he said the max was about 45) thus, you might actually limiting the car's by say, advance the cam degrees by 5 degrees (that's 10 degrees of crank shaft rotation) doing that may cause our ecm to freak and retard the timing to say.. 10-20 degrees ATDC(which pretty much neutralize anything you did to the cams, because the spark timing will be retarded, thus i won't even bother with the cam gears
just my 2 cents
just my 2 cents
Most people on here have that combo .. how about posting what degree they ended up setting at that "made a big difference" and when you say "big" exactly how much are you talking about? Thanks....
The only thing that you can do is add Plasma Booster Coils. Our ignition, this is gonna be long, how to explain this.......
The ignition in the Civic is Coil Per Cylinder.... I know that just about everyone knows this, but what you do not know is this... Each coil has its only little ignition in it. Since the coil its self is sealed. There is no way to seperate the control module (i.e. MSD SCI Digital Box) from the firing module (i.e. distributor cap). You have to look at it like this.... Each coil is like a tiny complete self contained ignition system all in one.
As far as advance/retard in the ignition, you may try a Honda PGM-Tester. All dealerships have these. The other option would be adjusting the timing with the cam gear. Technically, if you advance the ignition, that is the same as retarding the cam gear and vice versa.
General Rule for nitrous is this:
"reprinted from Tech. Articals from BG 2000; Barry Grant; Demon Carbs; Nitrous Works"
"....for nitrous injections up to a 75 shot, there should be a 1.5 to 2 degree retard in place to prevent premature explosions in the head. The added fuel/nitrous injection will need a slightly larger area for compression as opposed to normal conditions...." then they go on about different levels of induction of nitrous into the motor. Basically, for every 75 shot you need about 2 degree's retard...
I hope that this helps.
THOSE PLASMA COILS SUCKS ***!! I have had like 2 sets and when ever they are on my car it runs like crap and it stalls at idle... STAY AWAY FROM THE IGNITION SOLUTIONS COILS... sorry to type in caps, but I want to warn people....
I installed them properly, its not hard to install them.. anyways when i put the stock coils back it runs fine, then with the ignition coils it runs crappy... do the math.....
Bruce2
Sep 27, 2015 08:45 PM
