how to make windows roll up faster
Old Aug 18, 2003
SeThisBlaze's Avatar
SeThisBlaze is an unknown quantity at this point
Question how to make windows roll up faster
my mom's 95 accord windows roll up so slow....what can i do to make them roll up faster?
Old Aug 18, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
u can do what i do with mine. just hold the button, and pull it up haha
Old Aug 19, 2003
Mr.Modify's Avatar
turbo
Old Aug 19, 2003
Mr.Modify's Avatar
or swap
Old Aug 19, 2003
Elite's Avatar
Elite is an unknown quantity at this point
I heard they put grease by the windows on the side so they slide easier on my 2k2 civic does that on the right side because I dont think the body shop greased the side of the windows, and one side rolls up slower than the other, it kinda sucks.
Old Aug 19, 2003
Mr.Modify's Avatar
grease? wouldn't that mess up the windows some what like grease stains or something?
Old Aug 19, 2003
Neptune's Avatar
Neptune is an unknown quantity at this point
im actually having my window fixed right now, the auto down feature isn't working for some reason
Old Aug 19, 2003
Elite's Avatar
the honda dealer told me the grease the sides of the windows.
Old Aug 19, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
tell her to roll it faster...simple
Old Aug 19, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
Originally posted by Mr.Modify
or swap
Get off the board post *****
Old Aug 19, 2003
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
speaking of swaps... i wonder if i could swap a 03 accord power window motor into my civic... it has a auto up and auto down power window. and its slightly faster than mine.
Old Aug 19, 2003
she got power windows....so she cant roll it faster....come on yall can i get some help here
Old Aug 19, 2003
Skunk2ner's Avatar
its normal for the window motors to show some wear over time. age and use make them lose their efficiencey. sometimes they just need to be replaced.
Old Aug 19, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
Guys its a window - it goes up and down ;-)
Old Aug 19, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
A 5 shot of nitrous should do the trick. Either that, or replace the motor that rolls up the window.
Old Aug 19, 2003
LudlamTheory's Avatar
i boogie for the raindrops
only thing that would make THAT motor faster is 2 things... 1, change the gearing on the motor... that would require a metal shop... 2, up the voltage going to the motor... that would require the motor to have its only power supply...
well, there is a third solution:
DEAL WITH IT!!!!
be happy you have power windows
Old Aug 19, 2003
pheaton's Avatar
A descendant of 2k1civic.com
put another motor on the window . so there is 2 on each. . that'll blast it up.
Old Aug 19, 2003
Dr5D's Avatar
i would like my windows to go up faster in my civic as well, there is nothign wrong with them, but i have seen peoples windwos go up REAL fast. like with security or somthign, i dont know how they did it tho
if you put too much voltage to it it will fry real quick, and i dont think you could use a civic window motor cause the accord prob has larger windows that are heavyer
Old Aug 24, 2003
biohazard's Avatar
biohazard is an unknown quantity at this point
Check your windows for anything that would slow it down (stickers coming off, etc.) and the path that the window travels. You could have a bunch of dirt and junk in there and that could also slow it down.
Maybe a pick-a-part place could have other older cars and you could remove the module from those? Would be MUCH cheaper than new. You could even get a couple of old ones for the price of a new. Who would know/care that it was used? Only your wallet...
Neptune: did you do anything to your car lately?
A mod that requires you to disconnect the battery means that you'd have to reset the Autodown feature on your windows. How to do it is attached to several DIYs at the very end. You usually have to reset the idle limit also. Noticed anything weird with that either?
Old Aug 24, 2003
cdmx's Avatar
new motor!
Old Aug 24, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
what does that have to do with the motor??? its the actual switch!
Old Aug 24, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
again.. the auto down feature has NOTHING to do with the computer or ne thing electrical... its a Simple Plastic switch that causes this.
Old Aug 25, 2003
Jaykuai's Avatar
ish...
ACTUALLY
i got a 03 EX and the left window rolls up faster than the right one and its because the switch.. the motors are the same, the switchs are different..
Old Aug 25, 2003
biohazard's Avatar
Quote from HandA-Accessories.com install sheets
NOTE: Whenever the battery is disconnected, the driver's window AUTO function is disabled.
(To reset)
1. Start the engine. Push down on the driver's window switch until the window is fully open.
2. Pull up on the driver's window switch to close the window completely, then hold the switch for 2 seconds.
3. Lower and raise the driver's window to check operation of the driver's window AUTO function.
Well, that's why I thought you had to reset the switch... I read it in the manual ... Wasn't that what I was supposed to do?
There's something about resetting the idle ECU, but it says it'll do that eventually, you can help it along by resetting it yourself.
Thoughts/comments?
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
timpan
May 18, 2015 07:06 AM
1028CiViC
Bolt-on Engine Performance
Nov 18, 2001 05:02 PM
