Timing
Old Aug 14, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Timing
what are the advantages of advancing timing on our cars???
a frind of mine said it could be done and could give some gains, has anyone done this, can i do it another way or do I need a cam gear??
Old Aug 14, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
You need a cam gear for our cars. you'll get maybe a couple of hp (1-3?) at the wheel. the labor is expensive on our motors. I wouldn't recommend it w/o a cam & dyno session, which will yield much more due to the cam.
Old Aug 14, 2003
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
I thought that changing the timing only moves the power band and it doesn't gain or loose power.
Old Aug 14, 2003
HondaLuver's Avatar
Its a celebration bitches!
correct, it only moves it around when you only have 1 cam...
retard is for more high end hp
advance is for more lower end tq
Old Aug 14, 2003
Dr5D's Avatar
i heard that if you run 100+ octane it shows good improvement if you advance the timing
Old Aug 15, 2003
Macfay's Avatar
Macfay is an unknown quantity at this point
I think its the other way around...
Old Aug 15, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
nope he is right, advancing is for low end, retarding for high end...
Old Aug 15, 2003
IDQcivic's Avatar
acutally just read this article, its been posted before...
http://www.sportcompactcarweb.com/in...technology01a/
"On a SOHC engine, an adjustable cam gear will allow you to move the power curve to a specific area in the rpm band as described above. Like moving your peak power on a high-revving Honda to max out at 4000 to 5000 rpm. Typically to improve bottom end power advancing a SOHC engine will do the trick and the converse is true to enhance top end power. "
Old Aug 15, 2003
Da2K1's Avatar
Actually you guys are right about timing, i'm wrong!! (I mixed this up w/ ignition timing.) Thank goodness my post wasn't the only reply!!
Old Aug 15, 2003
opto_isolator's Avatar
Well if that's the case, what's the point of putting one on? I mean, all you're going to do is shift the powerband - not really getting any gains.
Old Aug 15, 2003
Da2K1's Avatar
Depends on your driving style. You want the peak of your powerband where you use it most. If you race, you want the powerband higher, if you cruise on the freeway, you want it lower.
Edit: i would get a cam as well at the same time, as the labor would not be worth putting just a cam gear. That would get you a lot of power.
Old Aug 15, 2003
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
crower cams on the way folks! imma grab that **** like hot cakes...since i already have the AEM cam gear....this probably doesn't relate to the subject, but the furthest i've advanced the cam gear was 5 tick marks...i swear man, u have to put a lil muscle into moving that center bolt....anyways...
Old Aug 19, 2003
Dr5D's Avatar
kinda like da2k1 said - it makes you take off faster, like for a race. but i have hear that its not such a great idea if you ever drive on the highway since you could be in 5th and basicly have then engine maxed out
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
