Angel eye projector problem
Old Jul 30, 2003
02CivicDX's Avatar
02CivicDX is an unknown quantity at this point
Ok any input would be greatly appreciated!!!!!
Had a low beam bulb blown on the pasenger side....replaced it and it works fine......couple of minutes later the driver side go very dim ....low beam on....but dim and the high beam on but dim as well (just like having the daytime lights on)
Replaced a blown out bulb on the passenger side and everything works perfectly fine again. But on the driver side the high beam light is partically on same with the night time light!!!!
I switched all bulbs and still the same thing. All the lights on the passenger side work perfectly fine (high beam and low beam) but on the driver side both lights only light up slightly. The high beam dont come on when truned on and with the low beam light on the high beam lights up as if i just had the dat time running lights on.
This is the first type of problem like this i encounter so any help would be greatly appreciated
Any suggestion????
If so can you get back to me ASAP plz. Send me a PM or email me at stevecroke@roadrunner.nf.net
Tanx
Steve
Old Jul 30, 2003
dj pyrotechnics's Avatar
dj pyrotechnics is an unknown quantity at this point
check the fuses.. i had a similar problem with my projectors
Old Jul 30, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
You need to put a larger fuse in if you are using xenon bulbs
Old Jul 30, 2003
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
fuses and check all wiring harnesses, i've had one melt on me... that's not your problem, but just check those too.
Old Jul 30, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
yup just had that last week..it was a fuse...
Old Jul 31, 2003
02CivicDX's Avatar
thanx guys
it was a fuse the was gone......i over looked the simplest thing
Old Jul 31, 2003
pheaton's Avatar
A descendant of 2k1civic.com
That's always how it is. You're soo worried about it not working that if it doesn't work, then it's automatically a huge problem.
Old Nov 17, 2003
Prism's Avatar
Prism is an unknown quantity at this point
Any idea how to fix the fuse then???
Old Nov 17, 2003
CivicHX01's Avatar
the fuse box in the left of the engine bay, look under the cover to see what all the fuses are for... just switch out the busted one for a new one... honda also included a nice dandy fuse puller and some extra fuses
Old Nov 17, 2003
Prism's Avatar
Nice one, your help is much appreciated I will attempt to fix it as soon as possible. Thanks again!
Old Nov 17, 2003
sno83oky's Avatar
sno83oky is an unknown quantity at this point
i got the angle lights too, but somehow it is kinda messed up, does anyone know how to reseal it and what do i need to do, because inside the light there, like moisture and also kinda foggy! dont want to damage the light or anything please let me know....
and if you got any input on what strut bar to get with my car that would be great, right now i have short ram AEM intake in there, so gotta be compatible with that in there too!..... please email me at run83ton@hotmail.com if you can help me out with the angle light
Old Nov 17, 2003
Oo_NIGHTMARE_oO's Avatar
Oo_NIGHTMARE_oO is an unknown quantity at this point
You can fix the fuse using aluminum foil. i did it ones to drive to pep boys to buy the fuse and replace the damage one.
carid
Jun 5, 2015 11:51 PM
cukaracha
May 16, 2015 07:36 PM
mugenca
Apr 16, 2015 12:15 AM
Professional
Jan 6, 2002 11:42 PM
vietnam
Dec 21, 2001 02:10 PM
