Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
2005 HCH Issue
Old Jan 23, 2020
Larry W Smith's Avatar
Larry W Smith is an unknown quantity at this point
2005 HCH Issue
Need help here please.. I recharged my car battery because it ran down due to the cold weather. After recharging it and putting it back in the car, it threw a check engine light and the OBD code reader won’t work. The ima system is in limp mode and won’t work as well for safety reasons...what the hell is wrong???
Old Mar 27, 2021
CivicHybrid03's Avatar
CivicHybrid03 is an unknown quantity at this point
Re: 2005 HCH Issue
Did you find a solution to this?
Old Mar 28, 2021
curlywurly's Avatar
curlywurly is an unknown quantity at this point
Re: 2005 HCH Issue
You can force the car to charge the battery, if you rev the car to 3500 - 3600rpm, it will then charge the battery.
I also purchased a 2003-2005 Honda Civic Hybrid EL-1 IMA Battery Grid Charger and it has been very useful for refreshing the battery pack, it fixed my IMA battery issue. There is some controversy if the grid chargers work as well as people say, all I can tell you, it fixed the IMA light on mine, for 9 months now. It cannot work miracles though, if the battery is aged and damaged then it can't do much. I'm only the second owner of my HCH, the previous owner used as his daily driver, 90% highway miles to his place of work, I think this has helped keep the car and battery in good shape.
Civic_MMV
May 19, 2010 08:26 PM
asdf123
Feb 6, 2009 01:14 PM
CarbonFly
South
Nov 4, 2005 10:06 AM
takadadojo
Aug 19, 2004 09:17 AM
