Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
This prob really stumps me!
Old Nov 12, 2006
MitsuGTRacing's Avatar
MitsuGTRacing is an unknown quantity at this point
The car is a 93 Civic Si... The car isn't wanting to start... It doesnt prime the fuel pump when I turn the key to start... I've check the main relay, it's good... Even swapped out the P28 for another... Its good... Heres the thing, I can jump a hot wire from the battery to the fuel pump, and it turns on, so thats good. All grounds are ohming out. The thing that has me questioning is the 2 yellow/black wires that are coming from the main relay arent giving me any voltage... Anyone know where those wires are going/coming from? If I'm not mistaken, those 2 wires are supposed to be hot, right? Its gotta have something to do with that connector because when I jump the fuel pump to turn it on, then try to start the car, it still wont start... (frikin gremlins ) Anyways... If anyone has any info to share, I'm all ears! Thanks in advance!
Old Dec 13, 2006
Anyone got any advice?
Old Dec 13, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
my advice is run a relay from the battery to the wire you know to be the power on the fuel pump and have it switched by the ignnition... if the factory electronics are acting funny on something as simple as a fuel pump, it's best just to bypass it.. it would cost $10 bucks to do this which is probably less than whatever replacement part you need
Old Dec 14, 2006
05blkrs's Avatar
i just read another post by you that says you dont have spark.. that means one of your main fuses/relays is out... it'll be in one of your fuse locations... gl
Old Dec 14, 2006
Thanks for the info! Yeah, Ive bypassed everything and can get the fuel pump running, but that spark prob is still defeating me. Ive changed out the Main relay under the drivers side dash, but to no avail... Is there any other relay that anyone can think of that controls the spark?? As I said, Ive swapped out the ECU already, so I know its not that either... Any and all help is immensely appreciated!
Old Dec 14, 2006
05blkrs's Avatar
there will be some relays and major (very large) fuses... they'll be the first thing that you can trace your power wire from the battery to... should be in a under hood fuse box...
Old Dec 15, 2006
whitehondacivicesi's Avatar
whitehondacivicesi is an unknown quantity at this point
I have exactly the same problem (i think),
Petrol pump does not come on, i have changed the main relay and ignitor and coil. Have you used the service manual to carry out the main realy checks?
The problem can be there for days then it will just decide to work! then the next time i go to start it, it will fail
I took mine to Honda and they said it was the ECU, i am now searching for a ECU to try
Old Dec 15, 2006
Ahhh, I just sent you a PM about that P28 you were looking for... Ive swapped out my ECU, and still... the problem exists... Ill still sell it to you if you want it, but I just dont want you to do what I did... I did check out my main relay, and I even swapped it with a brand new one... (I bought the new one before I ops checked the old one, which works 100%) What other stuff did you check on yours?? Have you pulled a spark plug to see if you have any spark?? My civic didnt start one time, and I just kept trying it... The fuel pump wasnt coming on, just like this time... Then all of a sudden, it started... It took like 10-15 min. That was the only other time it did that... Believe it or not, my SI has about the same mileage as yours at 170 something (even know my engine was supposedly rebuilt about 40-50,000 miles ago.) Keep me posted as to whats going on!
Old Dec 16, 2006
05blkrs's Avatar
so are you getting spark or no? if not, you can trace it back to the problem source and figure it out
Old Dec 17, 2006
Nope, No spark... Im going to have to chase it down further... Is there a relay that controls the signal from the actual key switch (from off to accy/on/start)? If there was something that had to do with that and the fuel pump and distributor, its gotta be that... (try to make sense of this post Its 430am...) haha
Old Dec 18, 2006
Do you have the civic Manaul - on page 11-32
As there is not a flashing engine light, the error does not come from this is where you should start... following through this i get to swap for a known good ECU
Also worth considering is page 11-116 - Main relay as you do not hear the petrol pump charge the system
When you turn on the ignition switch you will get 12V on pin 5 of the main relay, if there was a problem with the ignition switch you will not get this
I ended taking mine to Honda as it frustrated me checking everything £75, I thought it was worth finding out from the diagnostics board they have
Old Dec 19, 2006
Just got delivered a second hand P28 ECU after posting a request on "the parts gateway" and "breaker link" prices ranged from £75-£150 and I opted for the cheapest quote
The non-start fault seems to be fixed... 25 stop/starts so far and no recurance of the fault
Do you know your 2nd ECU is a good?
Old Dec 20, 2006
It was tested good before I bought it... It should be good at least! If not, I got had... So you say that your car will start now, but will just die??
Old Dec 20, 2006
No problems!
All fixed, It has been running fine for the last 2 days Approx 200 miles. All is well!
The non start fault has gone, petrol pump is triggered everytime i try to start the car
Old Jan 2, 2007
So it was just the comp, and all was well huh?
Old Jan 3, 2007
familycar's Avatar
r u getting power to the coil?? that is the first thing i would check after connections while not getting spark. sounds like the fuel issue is another problem and the spark issue is why the car wouldnt start after you jump the pump.
Old Jan 27, 2007
I havent checked yet, Im not in country at the moment, but its just weird that the spark AND fuel would go out at the same time.... I do know for a fact that the car wouldnt start when I jumped the fuel pump because of the spark prob... Im thinking about purchasing anoher ECU just to see if I got a lemon from eBay...
Old Jan 29, 2007
familycar's Avatar
its a good possibility but then again more unlikely than youd think. its pretty rare to get a bad ecu. i bet it is a passlock issue. have you had the ecu reflashed for the key you have??
Old Feb 18, 2007
Does anyone think a Crank Position Sensor would cause a prob like this??
Old Feb 20, 2007
familycar's Avatar
yes it could, but it would also throw a code
SimpleUser
Apr 24, 2021 02:54 AM
Civic720
Sep 10, 2015 10:06 AM
Ronin Nishimura
Jul 28, 2015 07:24 AM
Green02civic
Jul 27, 2015 10:48 PM
EliseKStewart
Jul 15, 2015 11:11 AM
