Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
help me please
Old Jul 21, 2006
vtechsi's Avatar
vtechsi is an unknown quantity at this point
help me please
doing some major work to b16a2. crower stroker kit,skunk 2 high compression
valves,aem fuel rail,port and polish,stage 2 crower cams, skunk 2 cams,aem intake,dc stainless header 4-2-1, dual coil springs intake and exhaust, 395cc injectors, aem fuel adj regulator... its going all into a 00 si..... what am i missing or are the injectores to small for what i am doing????
Old Jul 21, 2006
97_hatch's Avatar
97_hatch is an unknown quantity at this point
What is your goal? And I'm assuming this will be an all motor car, You might wanna add in a chipped ECU(P28) since it seems like you're lookin at revvin to at least 9,000rpm.
And has anything else been done to the block? I think those injectors should be fine also for a daily driver. Might want to just get a V-AFC to control your fuel though.
And if you're really goin all out, I'd go with a pro fab or ANR 4-1 header. You can probably find a nice used one for about $400-$500 bucks on honda-tech.com. But if you're not wanting to spend that much on a header go with a 4-1 header at least for some added high end power.
Just make sure it gets properly tuned too.
But sounds like a really nice head.. Just to with a LS/VTEC and your ALL Motor setup is good to go.
Good luck man.
Old Jul 21, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
i suggest just taking it somewhere and getting it tuned after you do all that.. that'll give you your best a/f and everything else.. if you're gonna be done after that, dont worry abotu getting a programable management unit.. and if the tuner is worth a damn, they'll be able to raise your redline for you.. so dont worry abotu getting it chipped just to raise red line...
Old Jul 24, 2006
vtechsi's Avatar
need help please
not sure what you meant by thay header you were talking about???
i was looking at getting a 4-2-1 header stainless header from dc sports.
have a place that will tune the ecu and chip it..what is the advantage of having it chipped versus having them set my redline and buying an s avc
Old Jul 24, 2006
vtechsi's Avatar
need help please
using the stock head and getting it port and polished versus using a ls vtech??????
