Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
05 Civic Si
Old Jun 1, 2006
hotngacpl's Avatar
hotngacpl is an unknown quantity at this point
05 Civic Si
I have an 05 Civic Si and I am looking to turbo it!!! Is there anyone selling a kit? What would you suggest for upgrades (internal and external) if any in order to turbo it without any mechanical problems.
Old Jun 1, 2006
fatboycg's Avatar
fatboycg is an unknown quantity at this point
we actually do. you can browse our site or call us for it 626 442 3988 ask for cg! or check the site at www.godspeedproject.com
ps. youll get problems with any turbo kit. Its all about the way you tune it. making sure the compression is right. you got a new car so im guessing it should be fine. most of it is bolt on.
pz
Old Jun 2, 2006
Darth's Avatar
Darth is an unknown quantity at this point
Its also about your internals.. you wouldnt want to run too much boost through standard internals, bolt on kit or not.
Old Jun 2, 2006
hotngacpl's Avatar
Do you know a good place in GA that I can go to get the internals upgraded and about how much do you think it would cost....
Old Jun 2, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
just buy a short block.. it's cheaper.. if you shop around you can find a built short block for about 2k and that way you can build the motor while you're still driving on your old one
Old Jun 5, 2006
Frantic's Avatar
Frantic is an unknown quantity at this point
2k?
you could almost buy a whole new engine for that price
Or a front cut for a bit more...
Old Jun 5, 2006
05blkrs's Avatar
Originally Posted by Frantic
2k?
a built up short block... as in one w/ forged internals.. 2k ain't tha tmuch.. after you buy the parts for over a grand, have it installed in the block (on these newer engines, it's not a driveway job.. i learned that the hard way) and all the block machining done.. it's 2g.. that's a good price...
Old Jun 27, 2006
vargasr66's Avatar
vargasr66 is an unknown quantity at this point
If you are staying within reasonable limits with boost (5-8#'s of boost) there should be no real need for upgraded internals as that is what most stock turbo systems run with no problems. If you're looking to run some mad boost then all forged internals are needed, upgraded valvetrain is recommended, a bad *** head gasket, also look into upgrading the fuel system as well. Just remember that turbo engines (unlike all motor jobs) like low compression. When You buy the parts or the short / long block let the place know that you want to run a turbo and they will be more than happy to help you out..
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
