Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
Clutch Problem...
Old May 18, 2006
imported_REDLINE's Avatar
imported_REDLINE is an unknown quantity at this point
Clutch Problem...
Hello all,
I'm new to the site and would appreciate your insight/suggestions as to the cause of my Honda's problem... I have a 2004 CIVIC SI that I bought new. Alot of highway driving - I've put 102,000 kms on it in just over 1.5 years. I've had problems with the following issue since about 30,000 kms and Honda can't find the problem. A reoccuring squeak accompanied by a slight 'crunch' when depressing the clutch pedal near the top of the release. Temperature doesn't seem to play factor. Both master and slave cylinders have been changed. The fork and bearing have been changed and all areas lubricated including the pedal. The problem is always remedied for a short period of time but returns (relentlessly). It's becomming very irritating - both the problem and the fact that Honda can't diagnose. Anyone encountered this?
Old May 21, 2006
fivespeed's Avatar
fivespeed is an unknown quantity at this point
I used to have weird clutchness problem. IMOHO:
Sounds to me like a lot of different things happening.
whatever stops it after maintenance means if belts or timings or lubrications is the problem, it's a supplemental mechanism that is working the squeak and "grab". That's why it takes time to recur.
That mean maybe alignment or something else is bearing down and the clutch mechanism and/or pedal is paying the brunt of it. This is a sympton of something else. A lot of highway driving might mean disposition of the physical engine case inside the chassis.
I used to have depression in the brake pedal that zigged and zagged between the primary and secondary brake cyldiners. That was fun.
I woul say road test this again and see what else is rpesent in the driving when it happens.
Are the shoks taking a lot of action? Are the axles working up and down bumps or rises or declines? is the steering constant or does the squeak and crunch ocurr when certain steering trends co-exist like turning, straight driving, or (whatever elements push around the clutch pedal mechanism).
Sounds like a physical problem that could get worse.
Old May 22, 2006
imported_Tricky's Avatar
imported_Tricky is an unknown quantity at this point
The only thing they havent looked at is the clutch itself.
I know its an expensive job but if you are hearing crunching, it should be looked at.
Its definitely the clutch crunching and not the gearbox right?
Old May 23, 2006
fivespeed's Avatar
Maybe the drivechain has issues? I assumed you already had looked at the clutch. Yes gearbox/clutch rigging conflict is bad. Get it looked at before it causes an accidnet or loss of motor control.
Old Jun 4, 2006
Clutch Problem...
Thanks all for your comments/suggestions as to possible problem.
Turns-out that the Master Clutch Cylinder is shot (again).
Reoccuring issue.
Makes me wonder... has Honda improved the part since the bulletin was issued last year?!
Old Jun 5, 2006
Frantic's Avatar
Frantic is an unknown quantity at this point
I was going to suggest master cylinder.. .what do you mean again, this has happened before?
How long ago did it happen? This isnt something that should be replaced regularly.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
