Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
Electrical problem
Old Mar 14, 2006
CVCTYPS's Avatar
CVCTYPS is an unknown quantity at this point
Electrical problem
Clock and stereo on my 93 Civic SI keeps resetting when I turn the car off for more than a minute or so. Anyone know a fix??
Old Mar 21, 2006
TypeR's Avatar
TypeR is an unknown quantity at this point
Hi
You have already posted three times on the forum.. stop posting!
Someone will reply soon enough. It does sound like a battery issue though.
Old Apr 4, 2006
sizzler's Avatar
sizzler is an unknown quantity at this point
Did you end up working out the problem?
Was it battery related?
Let us know!
Old Apr 27, 2006
JewelBeetle's Avatar
JewelBeetle is an unknown quantity at this point
Electrical problems are a real pain to deal with. We never experienced any with our Civic, but I had another car that was always giving me electrical trouble. First the dashboard lights would flicker, then the automatic window switch on the driver's side stopped working, and the really scary thing was when the windshield wipers would only work sporadically. No matter how many times I got the car fixed, another issue would pop up.
I hope you were able to get your Civic fixed.
Old May 2, 2006
fivespeed's Avatar
fivespeed is an unknown quantity at this point
Not battery sounds like alternator and circuit buzzback. Have a tech who knows the wiring check the flow on the wires with a voltage gauge. Then test the terminating points to see where their might be overvoltage and failure incidence that regenerates the programming from the circuit to the device.
Old May 2, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
is the clock run on the same power as the radio? my guess is it was re-wired at some point and is run off the red wire on the radio (this would be red on an aftermarket unit...) and if the yellow wire (again aftermarket) isn't hooked up securely, it will do that... i'm not positive how the clocks work on those cars, but the radio requires constant power for the memmory to be retained... and the red wire wich is the secondary power just switches the actual radio on and off... my guess is the clock is similar run off of the same 2 wires as the radio so if that constant wire isn't continuous to the battery, it will do that...
Old May 2, 2006
CharlieLink's Avatar
CharlieLink is an unknown quantity at this point
Code
It may sound silly, but have you tried resetting the code?
Be SURE you have the radio code before trying this!
Unhook the negative battery terminal.
Wait for a while (one hour should do it - to decapacitate).
Rehook the battery.
Reset the code. The method is in your manual.
Reset your auto station selection choices.
Reset the auto up/down on windows if you have that feature.
(I will explain how to do this if you wish.)
This may take care of your problem, it may not.
Good luck.
Old May 3, 2006
imported_Sam's Avatar
imported_Sam is an unknown quantity at this point
So did you fix this problem?
A friend of mine is having similar issues in his corolla.. let us know if you fixed it and how
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
steveneddy
May 19, 2015 02:39 PM
ywgflyer
May 15, 2015 05:05 PM
Ronin
Nov 17, 2001 09:46 PM
