Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Popping sound inside the car... Problem#322
Old May 7, 2010
CivicRage's Avatar
CivicRage is an unknown quantity at this point
Old May 7, 2010
Re: Popping sound inside the car... Problem#322
i bet the squeaking brake pedal is coming from the rear drums? might just need to be lubed up a bit, which requires partially dismantling the drum. you cant spray anything from the outside with the cover on.
for problem 2, i believe this is normal. the auto trans civics have a lockout so that you cannot shift from park to any gear unless you press and hold the brake pedal. pressing the pedal engages that switch mechanism (with a loud click sound) so you can shift into gear. completely normal, unless youre not able to shift into gear anymore.
Old May 7, 2010
CivicRage's Avatar
Old May 7, 2010
im not really sure if its a servicable part, but i know mine clicks alot louder when the car is turned off vs turned on and its done this since it was new. if you can shift into gear, i say just dont worry until it stops working.
Old May 8, 2010
CivicRage's Avatar
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
fvckbg
Jul 7, 2015 07:08 PM
reqy
Jun 1, 2015 07:05 AM
