Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Drivers Side key won't turn
Old Jan 18, 2010
MaxwellT's Avatar
MaxwellT is an unknown quantity at this point
When I put the key into the door lock it won't turn. I don't see anything visible preventing the key from turning. Any suggestions on what to try?
Old Jan 18, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: Drivers Side key won't turn
Squirt some lubricant into the key hole. A special lock lubricant is best. I've seen it sold even at Walmart.
Old Jan 18, 2010
i have the same issue, unfortunately lube doesnt fix it. i think the whole locking mechanism/actuator needs to be replaced. i sprayed lube everywhere with the panel off and it didnt work. the key feels like its gonna bend if i use it. but the power lock works fine cause its not tied in with the door key locking rods.
Old Jan 18, 2010
RonJ's Avatar
I would still say that the OP should first try lubricating the lock mechanism. Then go from there.
Old Jan 18, 2010
MaxwellT's Avatar
I will try that. I don't have auto locks as I have the VP Package so everything is manual (windows, locks, etc.)
Old Mar 4, 2010
zderdak's Avatar
zderdak is an unknown quantity at this point
I have the exact same problem now. The problem is that tumblers, springs and cylinder have worn out. Since you have no power doors you depend on that lock a lot. You have two options. You can buy a new door lock cylinder that comes with a key and then swap your old cylinder with the new one. In this case you will have to use separate keys for the two doors. Another option (I am working on this now) is to remove your old cylinder from the door, disassemble it and identify your tumblers (they have numbers on them 3,4, etc). Next, buy the new cylinder and buy new tumblers as well. Install the tumblers in the right holes and you can still use your old key after-all. Here is a link that explains everything: http://www.honda-tech.com/showthread.php?t=2237857. I think the permanent solution for this problem is to install power locks with keyless entry to your car. I am planning to buy this kit: http://www.a1electric.com/Merchant2/...Code=W01C-740T. It comes with a basic alarm as well.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
Supramk3
May 11, 2015 07:55 PM
ej8
Apr 13, 2015 06:36 PM
