Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Civic Compression Problems
Old Jan 17, 2010
stayc79's Avatar
stayc79 is an unknown quantity at this point
Cool Civic Compression Problems
My friend brought me his Honda Civic. He had overheated the car badly. He replaced the gasket and had the head reworked but when he put it back together it would just spin when he tried to turn it over. I pulled it back apart and replaced the head gasket again, checked the valves (good), checked the pistons and cylinders for cracks/holes/leaks, and everything looks good. I put it back together and I am still getting zero compression on all four of the cylinders. Not sure where to go from here??? Any ideas?
Old Jan 17, 2010
Re: Civic Compression Problems
did you check the head off the car to be sure the valves are sealing properly?
Old Jan 17, 2010
RonJ's Avatar
RonJ will become famous soon enough
Is the mechanical timing set correctly?
Do a leak down test to figure out where compression is lost.
Old Jan 17, 2010
stayc79's Avatar
He did a leak down test and the timing is good. Baffled.
Old Jan 17, 2010
RonJ's Avatar
If a leak down test was done, then where was compression lost?
Old Jan 17, 2010
stayc79's Avatar
He said there was a little loss in the exhaust side but not enough to have zero compression.
Old Jan 17, 2010
RonJ's Avatar
Sounds like the compression test was done incorrectly because it is conflicting with the leak down test.
Xuhme
21
Aug 7, 2023 03:40 PM
BREADFAN
Apr 15, 2015 08:58 AM
dooner24
Apr 14, 2015 07:51 PM
CapYoda
Nov 11, 2001 05:17 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
