Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Intermitent Wiper settings go crazy!!!
Old Jan 4, 2010
aldiaz24's Avatar
aldiaz24 is an unknown quantity at this point
I have a 2007 Civic Hybrid out of warranty. My wipers work fine on normal and fast settings. But they won't stop on the intermitent setting, and when I push the lever up for a one pulse option, it won't stop until after 8 or sometimes more cycles. Anybody had similar problems? I'm planning on replacing the relay first, then the switch. Anybody agrees?
Old Jan 5, 2010
CraigW's Avatar
Re: Intermitent Wiper settings go crazy!!!
There was a bulletin on the LX models with the fixed interval mode (you most likely have variable option) Not sure what years or models are affected.
Here is a link to a thread: http://www.8thcivic.com/forums/mecha...t=wipers+crazy
Old Jan 5, 2010
aldiaz24's Avatar
Thanks for the input, I'll go to the dealer and see what happens. Appreciate it
Old Jan 5, 2010
if they dont fix it, you may want to just try yourself. usually in these cases, the wiper motor is never the problem. it either works or it doesnt, based on electrical signal from the switch. people change them only to have the same problem come back a year later. its most likely the switch, and it might be fixable by opening it and making sure everything looks normal and cleaning the moving and metal parts. if it really is the wiper motor somehow, i would go find an aftermarket version from the auto store cause the honda one will have the same problem as your old one. honda likes to replace parts alot when there is a problem, but they rarely release a new part that actually solves the issue.
RSJ
Aug 13, 2016 01:06 PM
Klame9420
Aug 13, 2015 06:00 PM
suburbanite
Jul 17, 2015 03:05 PM
