EG Coolant Issue
SOHC D15b8 i have an issue.
my coolant seems to leak out after i turn engine off. it happened once where it was dry i added coolant drove delivering food on a cold night. looked in the morning and it was empty on the ground. doesnt overheat. heater didnt work but did wen i added coolant. looks like it leaks from under the intake manifold or somewhere back there????... on the last oil change i adjusted the air fuel screw and it sticks out more.. could that be the problem??
Re: EG Coolant Issue
No, the idle screw has nothing to do with your oil leak. I would check your coolant hoses going to the throttle body. It has to be a hose if your saying it under the intake manifold. It could also be a leaking head gasket on the back side of the engine, but i doubt that.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
zaboomafoozarg
May 30, 2015 09:21 AM
gqsang
Apr 16, 2002 12:31 PM
