Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
installing bigger fuel injectors
Old Nov 3, 2009
giantsrb45's Avatar
giantsrb45 is an unknown quantity at this point
So, yesterday i went to the junkyard and took 4 injectors from a 2.2 liter honda accord engine. My friend says since the little pin on the bottom of the injector from the accord is bigger than my current injector's pins it will give my car more horsepower. Is that true and will it work?
Old Nov 3, 2009
OCDjG's Avatar
OCDjG will become famous soon enough
Re: installing bigger fuel injectors
You'll run rich if they'll even fit in your car, whatever that may be. Only reason to want to add more fuel to your A/F ratio is if you're boosted.
Old Nov 3, 2009
TRIZ's Avatar
Dudes wrong. If they fit into your injector plate, and the flowed better, you'd still get the same HP as your stock injectors. Your ECU will just end up pushing the same amount of fuel through your injectors no matter which ones you use to keep a good A/F ratio. The only reason to increase them is if your current injector duty is maxed out. Unless your running a car with a turbo or super charger its not going to do you any good upgrading your injectors because you dont need more fuel being dumper in your cylinders.
Old Nov 3, 2009
lol yeah no difference. your stock injectors are nowhere near maxed out, most of the time they can handle much more flow than the engine will ever need.
docmartin14
Jul 30, 2015 11:26 AM
ZeroDegreze
Jun 17, 2015 11:10 PM
green01civic
Apr 29, 2015 01:36 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
