Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
how to do oil change??
Old Apr 21, 2009
richards200sx's Avatar
richards200sx is an unknown quantity at this point
hi guy
i just brought a 1999 honda civic 1.4,, and it need a oil change? just want to ask to anybody got any idea of how to change oil? thx
Old Apr 21, 2009
Re: how to do oil change??
park car on flat surface, set the parking brake, make sure car is in park for auto or gear for manual, then jack up front driver side and support using a jackstand (see owner manual for details and where to put the jack). never climb under the car with only a jack holding it up. next undo the drain bolt from the oil pan (theres an arrow pointing to it), and let the oil fall into a container like those oil storage thingies at the auto store. you may need a cheater pipe on the socket if the bolt was overtightened from last time. wipe the bolt threads and the pan threads. if the bolt doesnt look good, just get a new one. also you MUST use a new washer every time you change the oil. put the new washer on the bolt and then reinstall the bolt. tighten to spec, i think around 20 ft/lbs but just use the rule of "tight enough" with a socket using moderate force, dont tighten it as hard as you can. next reach up and unscrew the filter. you may need a filter wrench if it was overtightened last time. take it off and pour out any oil. get the new filter, and pour some new oil into it around the edges, maybe 1/2 quart at most, just enough to get it wet. then put a lil bit of oil around the rubber o-ring. reinstall onto the car and make sure it is HAND tight. thats it, tighten it as much as you can with your hand and leave it. youre done! lower the car back down, take off the oil cap, and pour in the rest of the first bottle (that you used to add oil to the filter with), and then pour two more bottles in. check the dipstick level and carefully pour in small amounts of oil from the fourth bottle til the level is at the max (top dot). do NOT overfill! very bad things will happen including vtec engagement problems and leaking seals, as well as engine damage. close the oil cap, then check to make sure oil does not leak from the drain bolt. start the car and drive it around slowly til operating temp, making sure to stop and check to see that there are no leaks. you can check the level one more time after the engine is shut off for 10 mins. go return the used oil to the auto store.
Old Apr 21, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
So I can take my old oil to Autozone and tell them here's the old oil and they'll take it? It's free right?
-Thanks
Old Apr 21, 2009
yeah i know kragen does it, and some autozone too. free. they dont take coolant tho only oil (and trans fluid).
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
BootyDo
May 7, 2015 04:46 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
AnotherDopeStyle
Jan 5, 2002 03:10 PM
