Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Honda Civic Starting Up
Old Apr 13, 2009
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
Exclamation Honda Civic Starting Up
Is it bad to start the ignition on your car too many times per day? Will it decrease the compression over time? What's so bad about starting the engine too many times per day for short distance pizza delivery driving??
Old Apr 13, 2009
kcari's Avatar
Re: Honda Civic Starting Up
your starter will likely wear out faster.
if you're worried about that, then leave the car on?
Old Apr 13, 2009
2005EM2's Avatar
My Honda Loves Me ^_^
I like to pick out my boogers, too.
Old Apr 13, 2009
well the main issue is it takes a ton of battery power to start the car, so too many starts and not enough driving to charge it back up will ruin the battery. the starter is made for many uses, in fact our 17 yr old accord has never had the starter replaced. and even if yours goes out, theyre so cheap and easy to replace under $100 and its just two bolts and a connector to remove above the trans. carbon buildup really is only a factor if youre turning the car off before the engine gets fully warmed up. otherwise if anything it will increase compression because deposits on the piston reduce the overall volume of space for combustion.
Old Apr 13, 2009
Red face Re: Honda Civic Starting Up
Thanks, Kyle.
Thanks, Gearbox.
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
twtron
Apr 17, 2015 12:09 AM
gabrown2
Apr 11, 2015 08:22 PM
