Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Runs a mile or two
Old Mar 31, 2009
Tony C's Avatar
Tony C is an unknown quantity at this point
Runs a mile or two
When I get my '93 civic LX started it seems it will run in the driveway forever. I take it on the road and after about a mile or two it starts to sputter and dies. Can't get it started for a while. Then I it runs great in the driveway again. I have replaced the Ignition module in the distributor, the fuel filter, the fuel relay module under the dash and the fuel injector pressure regulator. Any suggestions?
Old Apr 5, 2009
Fanatic4Christ's Avatar
Fanatic4Christ is an unknown quantity at this point
Re: Runs a mile or two
if you can smell the exhaust, and it smells kind of like rotten eggs, then there is a good chance that it is the catalytic converter.
Once the engine has heated up, you can look underneath the vehicle, just behind the engine and see if the catalytic converter is glowing red. If so, then it is probably stopped up and needs to be replaced. This could cause your car to stall out, die and backfire.
Old Apr 5, 2009
it seems to be a common problem. and if its clogged, usually at idle there isnt enough blockage to cause problem.its when you rev the engine that things go wrong.
Old Apr 8, 2009
Tony C's Avatar
Thanks for your responses. I will check it out and post the results. It may be a day or two.
Old Apr 8, 2009
04 Honda Civic's Avatar
no codes?
Old Apr 9, 2009
Tony C's Avatar
No codes, No lights. Just sputters and dies.
Old May 21, 2009
Tony C's Avatar
I removed the cat conv. and drove the car. Acted the same. Ran about a mile and a half then started sputtering and died. I was able to restart enough times to get it home. When it starts it turns over very slowly even though it's a new battery. Almost like it's trying fire long before TDC.
Old Jan 15, 2010
bella_bean's Avatar
bella_bean is an unknown quantity at this point
did you figure out what was wrong
Old Feb 17, 2010
Tony C's Avatar
Have not figured out the problem yet. Have not worked on the car in months. Looking for directions on back seat removal as I am told I may be able to access the fuel pump through an access plate under the back seat.
Thanks,
Tony
Old Jul 7, 2010
civic_si_ridin's Avatar
civic_si_ridin is an unknown quantity at this point
hello sorry to make this my first post but I have the same problem with my 90 civic si, i have replaced the main/fuel relay, fuel filter, numerous parts and still nothing, is it the dizzy, bad alternator wiring?
Old Jul 9, 2010
civtegra's Avatar
civtegra is an unknown quantity at this point
I know exactly what that is you should check your idle air wiring to make sure the iac isnt ****ing up thats what they do when there broke
Old Aug 8, 2010
Well I fixed my problem, I had an bad injector I replaced all my injectors with used ones and other than my O2 sebsor my car hasn't ran better since I bought it. so i donno make sure your injectors and rail are snug and the right stuff.
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
dragonsblood
Apr 27, 2015 12:28 PM
SLeePeR012
Dec 4, 2001 12:47 PM
supercivic01
South
Nov 30, 2001 11:27 AM
