Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
HID's on my Civic Si
Old Nov 27, 2008
edwin_90201's Avatar
edwin_90201 is an unknown quantity at this point
Im having a problem with my HID's on my civic, currently im driving an Ep3, just wanted to know whats wrong this them and if there have been other members with the same problem. My hid on the driver side doesn't turn on when i turn the switch it only flickers and it makes a buzz noise on the ballast but it doesn't turn on. I have a O-NEX system. any help will be appreacited..
Old Nov 27, 2008
Re: HID's on my Civic Si
do you have a separate relay harness with fuse that draws power directly from the battery? stock harness cannot normally handle the large power draw by both ballasts and often only one side comes on. so you need a new one with thicker wiring. at least 14 gauge wire with 15 amp fuse. and any 30 amp relay.
Old Dec 28, 2008
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
You might have bad fuses. My drivers side stock low-beams weren't working due to lack of power. Check your ground too.
Old Dec 28, 2008
DDragon7's Avatar
Or it could be a bad ballast. To check if its a ballast problem, switch the ballasts around and see if they do the same thing with the other light.
locozoko
Apr 6, 2002 09:00 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
