ignition coil
ignition coil
can anyone tell me what it entails too change the ignition coil, i have a little knowledge too do this myself, or what the cost should be too have either Honda do it or a mechanic do it, thanks
Re: ignition coil
Just get the replacement coil- its easy as hell. There is on nut to take off, and then you disconnect the wire, and pull the coil out.
Should take you two minutes
its a 36 dollar part on Majestic's website.
Official Rattlesnake Hunter
Re: TRIZ/ ignition coil
you can PM Triz if you want to talk to him directly, but 99 civic's do not have ignition coils
i assume your talking about this thread
https://www.civicforums.com/forums/1...tion-coil.html
Re: ignition coil
I moved the previous 2 posts into this thread... lol.
No problem dude. 99 vic just has spark plug wires that come off the distributor- no coilpacks.
heres the diagram for your car:
Upgrading your sparkplug wires to aftermarket wires (as opposed to the stock Honda ones) will help your performance and free up a few HP.
The parts your looking for are 1-4- they come as the wire and the "coil" together- you change the wire with the rest of it. Below are the itemized list from majestic honda- normally 20.57 at honda, they have for 14.40
20245 001 1 WIRE, RESISTANCE (NO.1) No Color 20.57 14.40 Qty:
20251 002 1 WIRE, RESISTANCE (NO.2) No Color 20.57 14.40 Qty:
20257 003 1 WIRE, RESISTANCE (NO.3) No Color 20.57 14.40 Qty:
20263 004 1 WIRE, RESISTANCE (NO.4) No Color 20.57 14.40 Qty:
They all have different part numbers because they are different lengths of distance from the distributor- so therefore the wires are different lengths. The part number on the left is a majestic part number only- honda part numbers are crazy long and have numbers and letters in them.
You can also buy them all at one- pictured as number 5 in the above image,
20271 005 1 WIRE, IGNITION (PRESTOLITE WIRE) No Color 75.70 52.99
These part numbers are for a 1999 Honda Civic 2 door EX, MT... Make sure when you look up your parts you get the exact car.
Heres a link to get you started: http://www.hondaautomotiveparts.com/...catdisplay.jsp
I found these under the "high tention cord- spark plug" category.
Oh... and if you dont know it.. you can post more than once in threads. So to reply just reply back in this thread. There are buttons on each thread that say "post reply" at the top and bottom of the posts on each page, or you can scroll to the bottom and start typing in the text box and hit submit. Oh.. and if someone helps you out or is a good guy, rep them- look at the bottom left hand corner of their reply post and click on the scale and type a little message when the box pops up.
Re: ignition coil
There is fuse underneath dash labeled ignition coil that's why i am a little confused, so you are saying that the spark plug wires have a coil in them. So Just replace the spark plug wires
Re: ignition coil
TRIZ question for ya. would there be any benifit in goning to a MSD, and can it be done with the top mounted coils we have. Like taking them out and putting 4 individual blaster coils? Wireing them?
Re: ignition coil
OK so 99 civics have the coil in the distributor. All you need to replace the coil is a phillips screwdriver. Remove the cap it's three phillips screws or an 8mm socket. Remove the rotor the screw can only be taken out in one position simply bump the starter until the head of the screw is visible from above and remove it with a phillips screw driver. Theres a small plastic cover that has to be removed to get access to the coil. two phillips screws to remove the coil and thats it.
Simple.
Please don't pass on false information and if you disagree with me i'm a honda certified mechanic at a dealer.
the accel part number for the high output coil for his application is acc11076
number 10 is the coil for your application
Simple.
Re: ignition coil
you must be high.
You can't do anything like that but you CAN just buy stickers for $12.95 and get the same results as you would if you could find aftermarket coilpacks
http://www.speedecor.com/spcopaemkit4.html Re: ignition coil
Moreover, defective ignition coils are notoriously sensitive to extreme changes in ambient temperature and humidity. So that may be a sign if you want to do an ignition coil replacement.
Re: ignition coil
Simple.
Simple.
BTW sorry for bumping an old post
Re: ignition coil
So there is no ignition wires "spark plug wires" then. Just replace the coil and the spark plug itself....Do they make "Performance Coils"?
Re: ignition coil
there are no wires. coils are a lifetime part unless they break and you are getting misfires. one company makes aftermarket modified coils but they are expensive and break every few months. and hardly give any gains. oem is already very good.
Re: ignition coil
Ok thanks for advice. My car has been running rough lately. When I shift into 2nd and 3rd i get a "back fire" or "mis-fire". Thats why im wanting to change the spark plugs and coils, unless you have a better idea?
Re: ignition coil
I have a 97 honda Civic LX i just purchased a MSD cap and rotor to also put a MSD blaster coil on there are they difficult to install. I am use to American Muscle but my buddy bought the parts and asked if I could install them.
Re: ignition coil
they are all the same, but unless you have a misfire problem, they never need to be changed. its not like older plug wires that age over time. the coils either work or they dont.
Re: ignition coil
im not really sure on the older civics, but you should be able to take ohm readings for all 4 wires and then compare to each other. if they are all close to the same value, they are fine. if one is way off, its bad.
h4ldol
Apr 24, 2017 08:16 PM
Bruce2
Sep 27, 2015 08:45 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
