Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Engine Knocking
Old Dec 18, 2007
mdawg's Avatar
mdawg is on a distinguished road
Engine Knocking
I have a 97 Civic LX with the Non Vtec engine in it. During the summer the engine run decent, gas mileage could be better but right now during the winter my engine knocking is BAD. Like its almost audible over regular music playing on the radio. It just gets louder as you rev up until the engine warms up a bit. Also I have starting problems when my fuel gets low which I think I have found to be a fuel pressure problem, How do I need to go about fixing that as well. Thanks.
Old Dec 18, 2007
DelawareDon's Avatar
DelawareDon is an unknown quantity at this point
Re: Engine Knocking
Chances are that neither one of those problems are simple and/or easy to fix. Take it to a competent mechanic you trust who will do the right thing at a fair price.
Old Dec 18, 2007
mdawg's Avatar
Re: Engine Knocking
What are we talking about that has to be fixed on an engine that is knocking. Does this mean It will lead to further problems if I dont fix it?
Old Dec 18, 2007
kynetic64's Avatar
kynetic64 is an unknown quantity at this point
Re: Engine Knocking
i had almost the same problem..well sounds like it anyways, it was my water ump that went bad. i would start it and once it got warmed up you could hear it really bad, like a tickin. a new one ran me about $300, they had to pull my motor to replace it though. but check and see if your leakin coolant
Old Dec 19, 2007
d5685090's Avatar
d5685090 is an unknown quantity at this point
Re: Engine Knocking
ok well chances are that u ran low on oil an that knocking that ur hearing is ur A-rod is banging up and down on ur crankshaft when it fires. im pretty sure thats it cuz it happened to me. u can replace the rod bearings but the problem is probably that the crank shaft is worn out and that means that u have to replace it, by the way a new one costs $900, yeah, and depending on the a rods that u have u have to get specific ones that match cuz suposedly there are different sizes for those bearings and u wud have to take off the oil pan and check the stamping on each rod. but b4 u do all this just take ur oil pan off and check if one or all of the a-rods have any play. ill check up in this thread later. pm me if you have any questions.
danace99
23
Jun 28, 2015 08:49 AM
Supramk3
May 11, 2015 07:55 PM
BootyDo
May 7, 2015 04:46 PM
zack22490
Apr 29, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
