tach works, speedo doesn't
Subscribe
Dec 10, 2007
title says it all (almost)
it's a 92 civic, 4 door AT. The tach works fine, but no speed is being recorded (or mileage, for that matter). Is this an electrical thing somewhere? I assume the sensor from the trans is working, since I am getting a good rpm signal. Suggestions?
Also, where do you guys find body panels/parts for these cars? I need a hood, front and read bumper cover in white as well front turn signals. Is this going to be a problem, and/or how much should I expect to spend?
thanks
Dec 12, 2007
Re: tach works, speedo doesn't
if the mileage isnt being recorded i wouldnt worry about it.. lol.. but no seriously i have a 95 coupe man trans that does the same thing.. if u look on the back side of the transmission there should be a sensor that sticks up.. well u have an auto so it might be different.. but look on the back side of the trans and see if u can find a sensor that screws into the trans.. thats yur speedo sensor.. it prolly needs to be replaced.. mine jumps around like a crackhead that needs a fix.. i think i need gauges tho.. but good luck man.. dont get pulled over man..
Dec 12, 2007
The tach doesn't get its information from the speed sensor (I don't think). I believe the tach signal comes in from the distributor or something like that. So, if I'm right, do what Xhondatech said to do and check your speed sensor on the trans.
Dec 12, 2007
I'll take a look. Should I be looking to replace the sensor or the cable? Good to know speed is measured separate from rpm. thanks
Dec 12, 2007
I would guess you should probably have to replace the sensor. Check the wire and connections before you do replace anything though
Dec 13, 2007
just check the connections...
Dec 14, 2007
wow. the connector plugged into the trans is GONE GONE GONE. It looks like it burned through itself pretty well. I think the sensor is probably fine, but I'm not quite sure what happened to the melted/burned connector but now I need a new one. Quick google search seems to yield no results, so I'm not sure where to find one -- should I just go to the dealer?
Jan 30, 2008
Ok, I have a new sensor and a new electrical connector, but don't know where the wires go. I have the haynes manual, and it appears to be wrong.
It says there is a black and two yellow/blue wires going to the sensor, when really it is a black, a yellow/blue and a yellow/white. Can someone take a look at their sensor and tell me which wire goes where? I'm mostly worried about sending power to the wrong pin and burning it out again.
Thanks
Subscribe
