Projection headlight from Ebay
So i have a question for all you guys out there that drives a 04-05 civic.
I seen civics that have those projection headlight. and they look like the ones off of ebay. but then i seen the same ones that isn't from ebay.
the question is.... is the ebay ones crap or ar they good. cus i heard from friends about ppl buying projection headlight from ebay and they leak. bulb kept burning out.
and i've compare the ebay ones to the local store ones, the price is a big different, so i want to ask you guys is the ebay projection headlights crap. and if anyone out there have bought them, how those lights working for them? do they work just fine????
I wil fix vBPlaza today
Re: Projection headlight from Ebay
the tycs are not sealed well fyi. there is alot of goo which is good stuff but gaps inside will leak water. also there are not enough vents in the back, so they may get foggy due to bad air circulation. there are only two vents, so i drilled more for a total of 5 and put some spare rubber boot things on the hole so water doesnt go in. when i had stock tycs, they always fogged up and took forever to clear up which means not enough venting.
ricer_em2
May 11, 2016 08:09 PM
zeshan7616
Sep 15, 2015 12:24 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
