95 civic, what kind of coolant?
Old Jul 15, 2024
hautcoupe_95_Dx's Avatar
hautcoupe_95_Dx is an unknown quantity at this point
Hi! i just bought my first honda, or any import really. it's in really good shape but it's been neglected for years. the previous owner got the radiator changed because "the a/c didnt work" i look in there and it has lime green coolant. i hear hondas take "type ii blue" but ive also heard that pre-96 takes a different coolant, "emerald green" what coolant should i use? i tried to search it up but theres suprisingly little info. i assume i need to flush everything including the heater core? i probably need to do a timing belt and water pump but i'm afraid that might be over my head. if i dont have an upper timing cover does the head still have to come off?
Old Jul 16, 2024
BrotatoChip's Avatar
Super Moderator
Re: 95 civic, what kind of coolant?
Really, any coolant is going to work. I've been using Prestone for years. If you really want Honda coolant, go to a dealership and give them your car info. They'll tell you what coolant to get.
Head does not have to come off for a timing belt. Unless it's overheating and needs a head gasket.
Old Jul 16, 2024
Colin42's Avatar
Green is fine, blue is fine.
Old Jul 16, 2024
the fluids that must be honda are: (unsure if same for older models, this applies to my 7th gen car)
Transmission (lower viscosity than usual, almost engine oil)
power steering?
Old Jul 20, 2024
power steering?
thank you, i would've never guessed to use honda power steering fluid.
Old Jul 20, 2024
I'm not so much worried about the brand as much as what color i need to get. i guess im gonna try to use blue after i do a full flush.
And good, it's a relief to know i dont have to pull the head, but this whole timing belt thing seems like alot for a newb like me. i'm still debating if i should take it to the dealership, the local honda shop, the random guy on FB Marketplace advertising that he works on hondas, or just plain trying to tackle it myself.
Old Jul 20, 2024
have a friend that knows cars around in case you hit a snag
a six-pack and it is settled
sjs8415
Mar 2, 2020 09:45 AM
FxckWil
Dec 21, 2015 10:25 AM
Aurora132231
Jun 11, 2012 12:21 AM
streetglower
Mar 10, 2006 10:06 PM
cdmx
Mar 12, 2003 11:28 PM
