Liqui Moly 2009 Anti-Friction Oil Treatment
Old Jul 29, 2015
emich's Avatar
emich is an unknown quantity at this point
Did anyone used Liqui Moly 2009 Anti-Friction Oil Treatment - 300 ml ?
Please post your results.
Amazon.com: Liqui Moly 2009 Anti-Friction Oil Treatment - 300 ml: Automotive Amazon.com: Liqui Moly 2009 Anti-Friction Oil Treatment - 300 ml: Automotive
Old Jul 29, 2015
mikey1's Avatar
Re: Liqui Moly 2009 Anti-Friction Oil Treatment
i never recommend or endorse the use of oil additives,
what is your reasoning for wanting to use this product?
Old Jul 29, 2015
GolNat's Avatar
Prelude Owner
The only thing that needs to go into the crankcase is motor oil.
Old Jul 29, 2015
Neither does Honda.
Old Jul 29, 2015
emich's Avatar
I met an engineer in Germany testing this product in a research lab.
Molybdenum Sulfide which is the main component reduces the friction in the engine.
I will try it in my old 1993 Accord and I'll let you know.
Old Jul 29, 2015
mikey1's Avatar
i believe that is what your motor oil does,
but im not an engineer, so what do i know?
Old Jul 29, 2015
emich's Avatar
you are adding that to the oil not using it instead.
Old Nov 13, 2015
0396's Avatar
0396 is an unknown quantity at this point
I use it all the time. My thoughts are, if it helps a little I'm good with it. No issues after 6 years of use.
Old Dec 11, 2015
bklynrx7's Avatar
bklynrx7 is an unknown quantity at this point
"I heard you like oil, so we added some oil to your oil"
Don't bother with this or any oil additive. If you want some Molybendum Sulfide in your oil switch Mobil 1.
I don't know if I can link to other forums here, but you can read about it on bobistheoilguy. This is basically like adding diluted assembly lube to your oil.
Old Dec 11, 2015
SimpleUser
Apr 24, 2021 02:54 AM
mjdiaz89
Jun 21, 2016 09:26 PM
brags
46
Jan 7, 2016 09:39 PM
mrwhos
Aug 11, 2015 02:03 AM
jessica19699
Jul 29, 2015 05:51 AM
