Winter Oil
Winter Oil
I live in Ontario Canada and normally let the honda dealer do my oil changes but I have decided after the last bill for it its time to just go to my local quick lube location. What is the type of oil that I should use for the winter IE: 5W-20 etc. Thanks for any info, I attempted to search the forum using "Winter Oil" but did not find anything specific on this.
Paul
Paul
Re: Winter Oil
RTFM
5w20 should be fine. The engineers decided on and stamped those numbers on your oil cap for SOME reason. It's not like they pulled those numbers out of thin air.
Oil technology has advanced exponentially over the last 10-15 years. You cannot listen to the stories that your dad and granddad tell about oil, none hold water these days.
If you think "oil is oil", that's wrong. Not all oil is the same. Lower quality oils are pushed hard because they generate the highest profits.
Even worse: Labeling is misleading, designed to dupe the unknowing consumers into buying anything on the shelf. It is still confusing to me, and I am a tech. "Meets or exceeds xxx spec" on a label doesn't mean it meets ALL areas of a given spec. Very misleading.
For example: General Motors; "Meets Dexos specs" is not the same as "Dexos approved". Approved oil will have the Dexos 1 or 2 logo displayed proudly on the bottle. http://www.gmdexos.com/
(As an aside, an independent and well respected oil expert, (that frequents a professional forum I am a member of), has mentioned that Dexos-1 specs cover Hondas specs, so any oil of the proper viscosity that is approved and stamped with the "Dexos-1" logo should be fine for our cars!)
Dealer oil is semi synthetic (bulk) and full synthetic (bottled). Hondas current custom blended oil is a close equivalent to Kendall GT1 Ultimate Synthetic. Mobil-1 and Pennzoil Platinum Plus in the proper viscosity are also perfectly fine. All are engineered to last the entire duration of the your oil life monitor without adverse engine issues under normal conditions.
Our bottled Mobil-1 5w20 has the Dexos-1 logo right on the front of the bottle.
Lesser quality oils can break down and cause damage before the oil life monitor runs out. The monitor has no clue what oil is really inside the engine, it can't sample the oil itself.
HTH
HTH
Re: Winter Oil
Here's another thing: You will not get out of there for the advertised price.
The quickylubes survive and make money by high-pressure upselling needless services to unwary consumers. I read somewhere that the average ticket ends up around $250, and they all come in for just the cheapass oil change.
I know, dealers can do it too.
As a consumer, you need to be very aware.
Re: Winter Oil
Paul
Paul
See: http://www.mobiloil.com/USA-English/...l_1_0W-20.aspx
It should be good for temperatures down to -48º Celsius
brags
46
Jan 7, 2016 09:39 PM
beeemerdude
Jul 23, 2015 03:53 PM
suburbanite
Jul 17, 2015 03:05 PM
beeemerdude
Jul 10, 2015 09:22 PM
