DIY: Scanning With An OBD 2 Code Reader (Video)
Old Dec 11, 2011
ProStreetDriver's Avatar
ProStreetDriver is an unknown quantity at this point
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1119& transactionid=1323641306-69633412&posted_by=ProStreetDriver_www.civicforums .com&youtube_video_id=cDB136WsQ0M[/autostream]
How to scan your vehicle with a generic OBD II code reader to diagnose the check engine light (CEL). How the code reader operates may vary between makes and models. OBD II was used on vehicles in the mid 1990s and newer. Before OBD II was the OBD I system which needs a specific reader for each vehicle.
Once the code is found, a simple internet search using your vehicle's make, model, and the code found will allow you to search what caused the issue, and what can be done to solve the problem. The internet search allows you to search the online database through car forums, online manuals, etc to help solve the issue.
If you have solved the issue causing the fault code and the vehicle does not clear the fault code, you may need to clear the code using a code reader. Or if you hate seeing the check engine light then you can clear it, but if the problem persists, you will need to fix the issue.
Old Oct 19, 2012
lowlife9's Avatar
Re: DIY: Scanning With An OBD 2 Code Reader (Video)
thanks for all the spam alex1986.
Kyrian
Jun 26, 2015 11:48 AM
Mnealo
Jun 18, 2015 10:11 PM
Schneiderman
May 24, 2015 01:14 PM
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
