99 Civic EX Maintenance
Old Mar 4, 2011
Fredd001's Avatar
Fredd001 is an unknown quantity at this point
Hey guys Im just wondering since you guys (i hope) are experts with civics could help me out on giving the best maintenance I can do on my 99 civic ex. I got it not too long ago it was mechanic owned so it runs good and i want to keep it that way. I did an oil change and spark plugs and wires but i dont quite remember exactly all i used. What would be the best fluids best oils i can use to keep this bad boy running. If its not too much to ask a list of all to do and the best brand of it for the car. Thanks alot
Old Mar 4, 2011
K20Z3's Avatar
2010 Civic Si
K20Z3 is on a distinguished road
Re: 99 Civic EX Maintenance
The best fluids are always debatable but there are a lot of regular maintenance items you probably should at least check the condition of when you first get your car, here's a small list:
Engine Oil
Transmission fluid (and filter if auto)
Coolant
Air Filter
Gas filter
Brakes
Theres probably a few more that I'm missing, they're components that wear out over time. All of these are regular items though that should be more or less highlighted in your owners manual which I suggest you read up on.
p.s. don't forget the horn fluid I recommend only synthetic go in there.
Old Mar 4, 2011
some of these might apply only for 7th gen, but just in case - from our Mcgiver gearbox fella
https://www.civicforums.com/forums/1...e-up-mods.html
Old Mar 7, 2011
LTDan's Avatar
LTDan is an unknown quantity at this point
I would check also that the timing belt/water pump service has been done. That's a big one. Honda recommends it be done after 6years/90k miles IIRC. I don't know about too many people doing that service themselves, but Honda will charge in the $700 range at the dealership for the service.
Old Mar 7, 2011
K20Z3's Avatar
2010 Civic Si
Thats a good one, I forgot about that. You should check this with every car you get because it could end up costing you an engine down the road. Luckily most newer cars are moving on to timing chains now.
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
ChristinaVHH
May 10, 2015 03:51 PM
cukaracha
Apr 26, 2015 08:39 PM
LexBoy
Nov 5, 2001 08:00 PM
