100,000 mile maintenance
Rep Power: 0 100,000 mile maintenance
so i brought my 2003 civic lx into the dealership for the ignition interlock recall thing, and since i just went past 100,000 miles, they're telling me i need to change the plugs and have the valves adjusted. they want $299.
now, i can change the plugs myself. but do i really need to adjust the valves? the car runs like a top, even with the old plugs. do i really need to mess with perfection?
1 Post
Rep Power: 328 Re: 100,000 mile maintenance
valve adjustment is pretty important... but its not a big issue until you start hearing a ticking sound in ur engine...thats when mostly u need it asap.
honda's valve adjustment @ 100k is more of a preventative maintenance in the long run. obviously it has some value in it or else honda wont suggest it.
i have 130k and my car still runs fine. maybe ill get it at 150. but remember, every car is different.
Rep Power: 787 Re: 100,000 mile maintenance
it will still run okay and loose valves wont cause engine damage, but you are losing out on some power and mpg.
Kenny the Ricer
Btw, if you're mechanically inclined,
Try this on for size
https://www.civicforums.com/forums/1...djustment.html
mattdoc
03-14-2017 12:10 PM
mrohitredd
05-28-2015 10:03 AM
juror
05-26-2015 06:35 PM
