break line pressure
Ok im was gnna change my gf break pads and idk my dum butt took off the bolt connected to the break line...i tightened back up the bolt and put more fluod in and pumped it up...it seems to hold pressure but then loses it all two sec later...im guessong i gtta bleed the break lines???
Re: break line pressure
Yupp you will have to bleed them now. Hopefully you know how to do this. All you do is start in the back farthest away from the master cylinder and work your way forward from farthest to closest. While doing this having someone in the car. Tell them to pump the brakes then tell them to hold it, when they hold it loosen the bleeder valve a little and let it come out then tighten it back up with them still holding it. Do this as many times as necessary and do the same with the rest.
OptimisticWay
46
Oct 15, 2015 02:16 PM
Green02civic
Jul 27, 2015 10:48 PM
cukaracha
Jul 23, 2015 08:50 AM
Kyles24
Jul 12, 2015 09:15 PM
