Antifreeze recommedations
Old Jul 16, 2010
volvokenny's Avatar
volvokenny is an unknown quantity at this point
Because I love my 91 Civic and I currently have the old green Honda antifreeze and is due for a change. I probably wouldn't be able to unscrew the engine coolant bolt and will leave the green coolant in the engine. As you all know Honda carries the blue antifreeze now I was wondering if anyone would recommend other brands?
Old Jul 16, 2010
Re: Antifreeze recommedations
stick with honda blue. it can mix with a bit of old green no problem.
Old Jul 18, 2010
MelJ's Avatar
Trance Addict
I'd just go with the OEM Honda like gearbox suggests. From what I've heard, other antifreezes can cause issues with the water pump seals, which is no bueno. If you're having an issue taking off that engine block bolt, might I suggest a breaker bar? I just recently changed my coolant and that BB made the job super easy. I have a 2000 Civic, but I'd assume that not much has changed with where that bolt is located at...
Old Jul 21, 2010
volvokenny's Avatar
Thanks for the advice I ended up using the Prestone Long Life (yellow jug and green fluid) which are sillicate and borate free.
SidCivic
44
Oct 12, 2017 03:39 PM
cferry7
Oct 3, 2015 04:33 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
herbiej
22
Aug 23, 2015 01:02 PM
krazymatt
Sep 2, 2009 01:31 AM
