Oxygen Sensor Replacement
Put my honda on a diagnostic machine and the code P0420 popped up. Catalyst system efficiency below threshold bank 1. I am going to replace the oxygen sensor myself, where exactly is this oxygen sensor located?
Re: Oxygen Sensor Replacement
thanks gearbox and lowlife, you were both right. After looking a little bit more i noticed that my cat. converter and manifold were cracked. Is this easy to replace? I looked at it and it looks like the whole assembly is fairly easy to remove and put a new one on. I have found assemblies ranging from $270 - $620. Is there anything that I am not seeing that you might know?
may want to see if its possible to weld the crack shut on the old one before spending $$ on another manifold. any shop that has welding equipment could take a look and tell you if the metal can be safely welded. the oem one has alot of problems and a replacement will likely have the same problem. they have aftermarket pieces, but who knows what kind of quality those have, or how good their generic cat is. for a short term fix, if it cant be welded, you might try that muffler mend putty at the auto store. ive used it to fix small holes in the exhaust before and it works great. same with metal weld epoxy. make sure to check the temp rating on the package because it needs to handle extreme heat.
KillerX
Apr 9, 2017 08:20 AM
thesushiboy
Apr 12, 2015 02:54 AM
answers to all these frickin turbo, nos, and super questions- im RANTING!!!!!!!!!! PLEASE READ!!!!!!
pinkytoe
Jan 8, 2002 06:05 PM
