Dry-Flow Air Filter Maintenance
I like my commute
Rep Power: 253 Dry-Flow Air Filter Maintenance
How often do you guys clean your dry flow air filter? I have the cleaning solution but it wasn't cheap and I don't want to waste it. I got the intake at the beginning of the summer, maybe I could get away with cleaning it in just hot water?
Rep Power: 787 wow its been over a year with my foam filter and its a lil dirty but still good and oily. no reason to clean that often.
Rep Power: 265 I was reading up online, and AEM at least says they make their filters larger than they need to be, so performance doesn't degrade if you get a little dirt in the pleats. Clean it when it starts to look nasty, or just replace it. You could also check the manufacturer's website, and see what type of mileage interval they recommend cleaning it at. Also consider though, that it depends on what type of intake/filter you have, and also the conditions/climate you drive through.
mattdoc
03-14-2017 12:10 PM
vtecbrah
05-12-2015 01:30 PM
