when to replace spark plug?
Old Jul 24, 2006
asunnyrain's Avatar
asunnyrain is an unknown quantity at this point
I have a 01 Civic LX with ~ 67,000 miles on it. I have new tires and a new battery. How long do you think I should wait to replace the spark plug? Sometimes, while braking to a halt, the engine shuts off. Any advice!
Old Jul 24, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
How long have U had the car. And if U have never done them and U have had it for long enough to put 67k miles on it U better do it now. WOW!!!
Old Jul 24, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
The manual says either 105k or 110k, i forget. They can last this long, but i'd recommend replacing them earlier. I replaced mine at 90k and noticed a difference. So, If i were you i'd go ahead and replace them, but rest assured if you cant get to them, they'll be fine to go longer. The engine shutting off when you comes to a halt sounds like a much bigger problem, not the plugs.
Old Jul 24, 2006
Hoosier282's Avatar
Hoosier282 is an unknown quantity at this point
Change them right now. You will notice a huge difference in the performance of your car. You are way over due for changing them anyways.
Old Jul 24, 2006
Civicly02's Avatar
i change them every 30000 miles
Old Jul 25, 2006
mystiknitekidz's Avatar
mystiknitekidz is an unknown quantity at this point
i asked the guy from honda. he said we dont need to change them until 105k because our sparkplugs are platinum something. i forgot. but yea, he said 105k. im sure you should replace them earlier though just because it becomes your car runs more efficient(should notice a difference if it is daily driven and gets beat up everyso often).
Old Jul 25, 2006
its double platinum, while they can last upto 100k with normal driving, but the performance wont be the same as new ones obviously. the only reason platinum is around has to do with car companies wanting to advertise longer service interval and because on some trucks it takes 4 hrs just to change the plugs. since on a civic it takes 5 minutes, i usually change mine once a year with some $2 copper plugs.
Old Jul 27, 2006
Tnsmongoose's Avatar
Tnsmongoose is an unknown quantity at this point
damn i over bye 2,500 ill change them this weekend...
Old Jul 27, 2006
Valdeezy's Avatar
Every 3k miles is whenever I change mine. Once a year, thats kinda long dont cha think??
Old Jul 27, 2006
Valdeezy-- what every 3k thats must get expensive...
Old Jul 27, 2006
Valdeezy's Avatar
not really. I do it with every oil change along with the filter. My plugs are were dirty as hell last time I changed them. I use the Bosch 2 plugs. I have tried different plugs these seem to work the best.
thana
Jun 15, 2020 07:05 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Micks2K1
Dec 10, 2001 07:11 PM
