wrong oil....
Old May 21, 2006
zik_zivik's Avatar
New Member
zik_zivik is an unknown quantity at this point
Question wrong oil....
can anybody tell me what would the after effect of what i did...
i recently had my oil changed about a week ago, i always bring my own oil. but this last oil change i accidentally brought a 10w30 instead of a 5w20.
is it going to damage my engine? any suggestions on what to do...
thanks alot......
Old May 21, 2006
skipbarber's Avatar
it'll be fine, just use the right stuff next time.
Old May 21, 2006
cIvIc_xyza's Avatar
rhein05 has been mutated to cIvIc_xyza
cIvIc_xyza is just really nicecIvIc_xyza is just really nicecIvIc_xyza is just really nicecIvIc_xyza is just really nicecIvIc_xyza is just really nice
its motor oil.. thats all that matters.. just dont do it again.. heell u can put a cooking oil in ur engine
Old May 21, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
nothings gonna happen, its gonna be a little thicker in cold weather but its summer so you will be fine
Old May 21, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
youll be just fine. car may feel a bit more sluggish than with 5w-20, but your engine will be fine.
Old May 21, 2006
zik_zivik's Avatar
New Member
Talking
thats a relief....
thanx a lot guys......
Old May 21, 2006
yea summer time no problems. just change it back next time.
Old May 22, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
thats a big negative. one of my buddies crazy uncle did that to his corolla...
Old May 22, 2006
S2000man01's Avatar
O RLY
uh, absolutely not.
Old May 23, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
loooooooool.....im at 56000 miles already and since i got my car in 02 ive prolly used the right oil one time.....dude you have to understand.....its a honda engine, best engine ever made. car might be crappy, slow, ugly, shitty, but the engine isnt. its not like your using some v6 oil or w/e....that 10w30 is fine and wont do anything to your engine
Old May 25, 2006
S2000man01's Avatar
O RLY
well, actually, all engines (including hondas) are designed to work with a specific weight. hence the reason cars have different suggested weights.
10w30 will make the oil pump work harder than it was designed to do, so long term, you could have premature oil pump failure. as for other side effects, again, remember the car was made to run on 5w20
Old May 25, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
im usein 5w30 synthetic oil.. is that ok? i just put it in about 2,000 miles ago.
Old May 25, 2006
HondaSaurusLX's Avatar
HondaSaurusLX is an unknown quantity at this point
I use 5W-30 synthetic as well. I live in a hick town where it's uncalled for to use an oil less than 10-W30. It's hard enough finding 5W-30 let alone 5W-20. So I just stick with the 5-W30 Mobil 1 and change it every 10K. I hear you can run a bit thicker with synthetic, but I have no clue whether or not that is true..
Old May 25, 2006
I change my oil every 3-4k miles
Old May 25, 2006
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
Why not order online? Just get a case of 5w20 from some site.... I would only use 5w20... its what the engine was made for.
I Hate ppl who say that you can use anything. Well you kind of can but there is a reason that it says 5w20 in the manual and its because ppl with way more schooling and experiance than you determined that's what would work the best.
Old May 25, 2006
S2000man01's Avatar
O RLY
you can go 3 times longer since you're using synthetic.
you're pissing your money away.
Old May 25, 2006
fatal Error's Avatar
fatal Error is an unknown quantity at this point
I use 0w-20 Amsoil.......
ricer_em2
May 11, 2016 08:09 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
