MPG indicator in cars
Old Jan 12, 2006
Blackpearl's Avatar
Blackpearl is an unknown quantity at this point
I travel in South California and I rented a car (Chevy cobalt). It was fine. I didn’t like the too plastic interior but the phonic insulation was ok and the rpm 600 rev lower then on my vic for the same 65 mi/h. For the first time I so the information button on board of a car. I checked out. It shows: TipA, Trip B, Outside temperature and odometer, MPG, Fuel left for X mi, Oil life x%, Coolant temperature.
This was the first time I had the opportunity to check out the features.
First I was excited but soon I realise that is just a "playing device" at least for some info.
I tested the MPG feature using the cruise control. First I set the cruise control to 65 mi/h and after about a 1 min I reset the MPG indicator to have better calculation. First indicate 39.1 MPG. Hooo. You try to beat Honda!! Then the indicator just dropped down to 34 in about half hour. Hmm that is more real but how it calculate it?
I tried at 40 for 5 minutes on empty street. The indicator show 58 MPG . I pressed the break to go down to 35 and then slowly up to 40 again (took about 30 seconds) and use cruise control again. The MPG indicators show 30 MPG. Well after another 5 min the MPG indicator didn't recover. So the computer is not doing an averaging. That indicator is useless.
Beside that fake MPG indicator the coolant temperature, outside temperature indicator where fine.
Other question is about the "oil life" indicator. When I was starting the trip was 48%. After a 400 mi trip, the indicator was 43%. If is going down like this then is hell.
I can’t comment on the "Fuel remaining for X mi" indicator. If is based on the MPG then is a joke. If is based on Fuel level in the tank then is imprecise.
Question: Any oppinion? Experience?
Old Jan 12, 2006
zadscmc's Avatar
zadscmc has a spectacular aura aboutzadscmc has a spectacular aura aboutzadscmc has a spectacular aura about
The mpg indicator is standard equipment on some Honda Civic models, namely, the Hybrid.
The mpg indicator, linked to Trip A and Trip B, give a *fair* indication of your mileage. My Trip B, which I have never reset since day 1, reads 54.5 mpg, over 50K. My Actual mpg, using fuel consumption calculation (by hand) is about 52.7. So there is some inaccuracy.
It is handy to have, and, along with the Instantaneous display (histogram), make useful tools for those (who have nothing else to do) who are fuel conscienous.
BTW, the Hybird (03-05) doesn't have a Fuel remaining guage. I am not sure about the '06.
Old Jan 12, 2006
CuRiOuSfIsH's Avatar
Back From The Banned!
my experience was with a BMW M3. I say in the city, it's just about completely useless. The indicator varies depending on how much throttle is put in.
Old Jan 12, 2006
swifty2k's Avatar
swifty2k is an unknown quantity at this point
I've got that on my yukon denali. I never use it, as soon as I hit the gas, it goes to 0mpg
Old Jan 12, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
its not scientific like a temp gauge. its a educated guess, the harder you push the lower it will be.
Old Jan 13, 2006
Jrfish007's Avatar
The oil life thing is on the new civic's too. I'm not sure about GM, but Honda calculates oil life based on engine load and RPMs and basically does an engergy balance and applies that to the oil. The problem comes in that if use non-Honda oil, the amount of ware the oil can take is differrent.
Old Jan 18, 2006
Blackpearl's Avatar
I was tinking that the oil life indicator take the data from some photo reading (oil darknes) or something similar.
So honda need some kind of reset after the oil change I guess. Do you know how?
Old Jan 20, 2006
Jrfish007's Avatar
Yeah, my '06 has to be reset each time you change the oil init. You have to hold a certian button down and turn the key or something like that, I've only done it once (the car has just over 5k on it now), so I generally don't remember until I've done it about 5 times
Old Jan 20, 2006
the stuff in the cobalt is garbage. they just put that in to have a better selling point. not that any of those functions actually work except the odometer hopefully.
bsmiley
Apr 27, 2015 01:27 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
BREADFAN
Apr 15, 2015 08:58 AM
dooner24
Apr 14, 2015 07:51 PM
