1st oil change for low mileage car
Old Dec 23, 2005
nyyanks81's Avatar
nyyanks81 will become famous soon enoughnyyanks81 will become famous soon enough
Question 1st oil change for low mileage car
I have very low mileage on my 9 month old 2005 Civic right now (2300 miles) since I only use it mostly for weekends. When should I bring it in for the 1st oil change?
The original factory oil is still in it and from reading other posts it is best to leave it in for the first 5000 miles.
My car will be 1 year old in March '06. Should I get the oil changed at that time (1 year mark) even thought it may not have reached 5000 miles?
Old Dec 23, 2005
DDragon7's Avatar
Yeah, you should change it either at the recommended miles or less, or in 6 months, which ever comes first. In your case 6 months, and plus your car is new, so you should change it soon, because new cars tend to have more junk in the oil from removing all the metal shavings if any out of the holes when new. (People usually change their oil early for new cars)
Old Dec 24, 2005
liliechen's Avatar
liliechen is an unknown quantity at this point
first oil change is always very important, because it's a new engine it needs break in, so there will be lots of metal shavings, you should follow the instruction to change it as soon as you get to the milage suppose to be.
Old Dec 24, 2005
DDragon7's Avatar
Or before
Old Dec 26, 2005
Jrfish007's Avatar
Use Valvoline Max Life. Yes it is a oil made for higher milage engines, but it uses the same stuff to protect older engines as Honda use to "break in" you engine, and that's moly. Use this then in 6 months go to your oil choice, what ever that is. Just make sure to change it every 6 months from now on. Considering how much you drive I would go to a dino oil, since you will never see the adavantage of synthetic oils (which is higher milage between oil changes).
Old Dec 26, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
just use oem honda oil ur not performance u dont need aftermarket brand
Old Dec 27, 2005
Jrfish007's Avatar
If you don't mind what performance oil costs and only getting econo oil, yeah go for it!
Honda OEM oil = $3 a quart
Castrol syntec blend = $2 a quart at Walmart... same stuff, but more money at Honda, who would have thought
Old Jan 23, 2006
sPiKeNaToR's Avatar
sPiKeNaToR is an unknown quantity at this point
Cool
Follow the instructions in your manual 1st change not before 8000km/5000miles. As it's special break in oil. My Dealer told me likewise, and added it's OK and will not void the warranty to wait till 9000kms for 1st change. Apparently a longer breakin period is good. It is important to not rush the 1st. Following 1st oil change (Shedule A) The more often you change your oil, obviously, the better, after all oil is the life blood of your car. Just like with other things in life, the 1st time is the most important, so don't rush it!
Old Jan 25, 2006
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
5w-20 honda motor oil + filter after 5000 miles or within 6 months.
then you run that for another good 5000 miles and change to whatever you like.
Old Jan 25, 2006
project: EM2k4's Avatar
project: EM2k4 has a spectacular aura aboutproject: EM2k4 has a spectacular aura aboutproject: EM2k4 has a spectacular aura about
I would use synthetic oil, I have and I noticed a huge improvement. It's only a couple bucks more so don't be cheap about it.....
Old Jan 29, 2006
nyyanks81's Avatar
Im predicting that my car will have about 2700 miles when the 1 year mark is up. I should have the 1st oil change no matter what the mileage because its been there for 1 year?
It will probably take me 1 more year to reach 5000. I mean should I leave the original oil in for 2 years?
Old Feb 2, 2006
Jrfish007's Avatar
Oil is generally only good for 6 months, I'm not sure about the factory oil though. I would stick to changing it every 6 months unless you get the extended life oil, which really isn't cheaper, but it is sometimes worth to just worry about it once a year. I think it was around $50 to use the mobil 1 extended life in my towing truck, which sees about 2,000-3,000 miles a year. It is a little cheaper to use normal oil and change it every 6 months, but I would rather pay the extra and just do it once a year... do what you want, but follow the manufacture suggestion on the oil container.
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
CivicVoz
Apr 16, 2015 08:07 PM
NeoMagus
Nov 7, 2001 10:10 PM
