WD-40 on wheel studs and lug nuts?
#31
Originally Posted by pon55
You have open or closed lugnuts?
If they are the open type, seal the end with silicon seal.
#32
Crayons taste like purple...
Rep Power: 264 as far as this thread goes....the one thing I would have input for is to use antiseize...not some cheap white grease from autozone..something like this....Damn thats a long *** URL EDIT: just a dab now don't go slopping it on there
anyways because if you'll notice on some newer vehicles manufacturers are starting to put some stuff on the studs and some bolts....alot cheaper then hearing about broken bolts from customers who mod...plus the fact that I don't think anyone on here said anything about heat expansion...hat is the real killer...not some kid using a 20 Tw on your bolts...@myshop we have impact wrenches we also have torque sockets and TW...if you know what you're doing you don't have to worry about screwing up someone's rims studs or lugs....only vehicles I'm scared of messing up are the big trucks that come in...the ones that take in excess of 140 tq.lbs. those are the ones I'm scared of breaking cuz of all the weight and such...
#33
Originally Posted by Jrfish007
Once the lugs are overdone one time, they are done for. That elastic thing Tacheon is talking about, it's like a rubber band for metals, they do indeed strech. The metals used in both the stud and nut are designed to strech at the specific torque. Once a stupid shopover tightens them, it looses the elastic force. Think of a rubber band, you can strech it and strech it and it will go back to the normal most of the time. But if you strech the rubber band to far (read putting to much torque on the the lug nuts) and then the rubber band doesn't go back to the orginal shape. Same with the lug nuts, if they get over torqued, the threads will not be able to deform properly. I can get much more complicated, or you can just take my word for it.
I ran into this when a shop put over 120 ft-lb torque (that was as high as my TR would go) on the lug nuts, the lugnuts where contstantly falling off because they would not lock on to the studs and I had to replace every stud and lug nut on the car to get everything to stay together.
now I don't know about this overtorqued...but I know if you let someone wail on your bolt with an airsocket it could eventually strip ouit both not just torquing too much unless they don't stop after the clicks and just keep torquing and torquing...cuz eventually the splines are going to run out of room and have to start bending in on themselves...
#35
Originally Posted by Johnold
what about this stuff?---> this stuff would do you some good around the wheels where rust is.
#36
Rep Power: 0 i wasn't talking about "EVERY PART THAT MOVES" i was just talking on some rusted spots like around the center hubs on the wheels and on the threads on the studs. but OFCOURSE you have to clean it first. maybe with some SUPER FINE steel wool first and THEN with that lithium grease.
#37
#38
Rep Power: 0 do you guys know how long threaded studs are on a 7thgencivic? i'm wondering if a lug nut lock that has an over all length of 0.945 inch fit perfectly on the stud with an aftermarket wheel on?
#40
WD-40 is good for keeping garden tools from rusting but other than that, it's a pretty lousy cleaner/preservative/lube.
The stuff is, in essence, perfumed kerosene so I'm not surprised that it doesn't last long. Instead, use the same stuff you use on sparkplugs aka any commercialy available anti-seize.
juror
Suspension DIY
07-30-2019 03:28 AM
califcamper
07-21-2015 10:34 PM
