Bulb guide for 01-03
Old Jun 23, 2005
dirtySAMURAI's Avatar
I log in from time to time
Coupe headlights:
H4 - Main bulb, Dual filament
168/194 - Parking light, Single filament
7443 - Turn signal, Dual filament
Sedan headlights:
Coupe taillights:
7443 - Brake light, Dual filament
7440 - Turn signal, Single filament
921 - Reverse light
168/194 (Same bulb) - Parking light
Sedan taillights:
7440 - Parking light, Single filament
168/194 - Reverse light
PM me if there is something wrong with this list
Old Oct 11, 2019
Kenneth Forward's Avatar
Kenneth Forward is an unknown quantity at this point
Re: Bulb guide for 01-03
I have a set of spyder halo headlights for 2002 honda civic sedan .. what size led bulb do I need for the halo itself .. not the high and lows or drls or neither market lights i just need the size for the halo bulb itself
Old Oct 11, 2019
Colin42's Avatar
Contact spyder
Old Oct 11, 2019
The LED for the halo is likely not a replaceable component. They've typically been diodes soldered in illuminating the acrylic ring. If you wanna change the color or replace a failed diode, you'd (highly likely) have to crack it open and do some DIY electrical work.
Old Oct 16, 2021
cnovalles73's Avatar
cnovalles73 is an unknown quantity at this point
Originally Posted by dirtySAMURAI
Coupe headlights:
Sedan headlights:
Coupe taillights:
921 - Reverse light
Sedan taillights:
Any idea what bulbs are used in the climate control cluster? I'd like to make the swap to LED.
carowcliffe
Sep 11, 2011 04:43 PM
danzz1234
Jun 19, 2011 01:36 AM
MURDOCK
Lighting
27
Mar 28, 2007 12:00 PM
blue03civic
Lighting
Aug 18, 2004 09:59 AM
guamcivic2k1
Lighting
Jun 10, 2004 11:33 PM
