DIY how to remove door handle/ armrest
Sorry guys its nothing spectacular and I dont know where to put this but here you go...
Window switch DIY
1.) Locate the little clip on the underside of the switch holder/arm rest.
2.) Using your flat head screw driver push the little clip up while pulling on the bottom half of the arm rest.
3.) Towards the rear of the armrest are 2 screws remove those
4.) Then lift the unit in an upwards motion started from towards the seat moving to the door…its takes a little persuading but it should pop off.
5.) That’s what it will look like with the whole unit removed.
Mods move if necassary and delete if not needed. I did this for Nate at LEDautomotive.com for his LED conversions. Check it out some time they are hella bright
Pics wont post so check out my ride section for the pics
Window switch DIY
Pics wont post so check out my ride section for the pics Last edited by Jeffsta17; Dec 12, 2004 at 03:24 AM.
MamaBear2015
May 18, 2015 07:37 PM
civicdown4u
Nov 21, 2001 10:44 PM
