How To Paint Trim Pieces
Old May 17, 2004
Forum Bot's Avatar
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
Post How To Paint Trim Pieces
<font face="Verdana">In the EX and LX, there are parts of the trim pieces painted silver. You can buy the silver center piece from Honda for about $98 (update: you can't buy silver, only gold like the sedan), or you can paint it yourself. </font><p></p><ol><li><font face="Verdana">Remove the center piece by first removing the heating and cooling ***** (just grab and pull), and remove the accessory plug trim piece (looks like a cigarette lighter plug). You will need to put a thin rag on a flat tip screw driver to get that trim piece off. Unplug the plug. Now, if you look up in there, you will see two 8 mm bolts(silver), remove these, then push the bracket up until the center piece pops out. You will have to push hard, but it will push out, the radio and everything is connected to it.( do not attempt to pry this piece out with the rag and screw driver, it will warp the plastic and will not have a good fit when replaced! Trust me ...I know </font><p></p></li><li><font face="Verdana">Remove all the plugs(don't worry about labeling, each plug is different), the vents, the radio, and the pocket (if equipped), and remove the rings that go around the heating and cooling *****. You should now have just the plain trim piece. </font><p></p></li><li><font face="Verdana">The next step requires 2 things, any automotive WHITE primer, and a can of PLASTI-KOTE import color, Honda silver, part # 5304 (got mine at PEP-BOYS, they sell a whole slew of PLASTI-KOTE paint colors. This is a perfect match to the existing trim pieces being because it is Honda Silver. Spray two light coats of the white with five minutes between each coat, and be careful of runs. Then spray three coats of the silver after 15 minutes of the last coat of primer, also with five minutes in between coats. Try to get good coverage with the three coats without runs, because after that, you start to loose the texture of the plastic. Let it dry for an hour. </font><p></p></li><li><font face="Verdana">Put it all back together. You just saved @ $93 </font><p></p></li><li><font face="Verdana">Here are the results on the center trim piece, pretty nice. Thanks to 01CIVICEX for this DIY.<br /></font><br /><img height="240" alt="painted Trim" src="/diyimages/Pict0003.jpg" width="320" border="0" /></li></ol>
Old Mar 15, 2011
cmsdragon87's Avatar
cmsdragon87 is an unknown quantity at this point
Talking Re: How To Paint Trim Pieces
I decided to paint my trim, too, but i painted much more than just the plastic around the head unit and climate control.
I used 1 can of Duplicolor Adhesion Promoter, 1 can of Rustoleum Clean Metal White Primer, 2 cans of red Duplicolor Metalcast paint, and 1 can of Rustoleum Acrylic Enamel Gloss Clear Coat.
Picture055.jpg?t=1300223100
Everything (besides the part around the radio and the part around the guages) popped off easily with a flat head screw driver. There were just two screws at the top for the part around the guages.
After cleaning everything well, I put on two coats of adhesion promoter, waiting about 3 minutes between coats. That stuff dries very quickly.
After another 5 minutes I put on two coats of the white primer with about 3 minutes between.
10 minutes later i began painting with the Metalcast and did about 3 coats with 3 minutes between, again.
Another 10 minutes later, I did two coats of clear and of course 3 minutes between coats.
LET EVERYTHING DRY OVER NIGHT. Trust me, I got impatient and left a big mark on one of the a/c vents. If this happens, you can touch it up with a red sharpie and it wont be AS noticeable.
Some of the pictures make it look orange but in person its all red, even in the sun. Also, it would let me resize the freakin images, sorry
Results.
Picture061.jpg?t=1300223868
Picture060.jpg?t=1300224166
Picture059.jpg?t=1300224217
Picture057.jpg?t=1300223983
Picture058.jpg?t=1300224093
Picture056.jpg?t=1300223919
Old Mar 15, 2011
MindBomber's Avatar
Live for the Twisties
Looks good, don't get tempted to try painting the dash though, that never works out.
Old Mar 15, 2011
Kennykid2002's Avatar
Kenny the Ricer
Why is everyone trimming their inside red now?
New trend? Maybe I should join in lol
Old Mar 15, 2011
I would definately reccomend painting your trim red. It gives you the feeling of driving a race car, with a 1.7L engine. Plus if you know what youre doing it looks prfessional
Old Mar 16, 2011
Kenny the Ricer
I just literally...facepalmed
Old May 13, 2011
civicchick2001's Avatar
CivicChick2001
civicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to all
I really like how this turned out.. I'm wondering if it would look as good in navy/blue color too.. My car is navy and just tryin to fix it up. When u say the parts pop off easy with a screw driver, are they easy to get back in? Also for the piece around the gauges, do u just unscrew and it comes loose? Or are there more steps to this? I also have a manual transmission, so does anyone know if the ring aroud the stick shift pops off too? Hate the gold color around it.. Not sure why it's that color when my car is navy with chrome trim everywhere.. Anyways, thanks for any advice
Old May 17, 2011
rosaskye715's Avatar
rosaskye715 is an unknown quantity at this point
I'm also doing trim painting and having trouble figuring out how to get the armrest off the door panel so that I don't have to worry about doing a super tape job to avoid getting it on the fabric. Any videos? Ariticles? I need detailed description so I don't ruin it. Thanks
Old May 17, 2011
BTW, it's a 2004 Civic EX coupe
Old Jun 3, 2011
CivicChick2001
when you take the trim off around the left and right vents, does the entire vent come out? or just the trim part? tried it the other day and the whole vent was moving so i stopped. lol
Old Jul 13, 2011
CivicChick2001
bump. still wondering this.. cuz im gonna do it.
Old Aug 1, 2011
BigCivic's Avatar
BigCivic is an unknown quantity at this point
My car isn't actually a Civic but a Honda Stream which is similar but not avaliable in the U.S. Anyway I retrimmed many parts in orange leather and painted other parts that I couldn't trim in orange paint to match.
Old Aug 1, 2011
BigCivic's Avatar
You can see my whole ride at http://www.cardomain.com/ride/439565...a-civic/page-2
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
carid
Sep 28, 2015 10:13 AM
speedlever
Sep 24, 2015 07:18 PM
