DIY - Honda civic ep2 Type R spoiler install (European car)
Old Sep 17, 2022
Driclith's Avatar
Driclith is an unknown quantity at this point
Lightbulb DIY - Honda civic ep2 Type R spoiler install (European car)
Hi i wanted to make this post for everyone because on the internet and forums this topic is patchy, its not really shown how to do it so here is my point of view on how to modify Ep3 type R spoiler to fit ep2 rearhatch.
This took me 2 hours total for the cutting sanding and fitting, on my car someone had allready made run trough hole for the brakelight plug so it cut the time of the project a littlebit.
If you need to make the run trough hole you will need a drillbit and preferabely a rubber round blug or silicone sealant so when you put the rear brakelight wire trough you can seal it from water to get in and from rusting.
The hole needs to be made in between the 2 middle bolt holes on the rearhatch.
Remember when using a dremel on this use safety glases and a facemask so the peaces that come of flying dont hit you in the eye and the smell of the abc plastic melting ain't pleasant
The tools and items i used for this project were Dremel, silicone sealant, 10mm socket and rachet, straight edge molding, masking tape (you might need a drillbit to make a hole to the rearhatch for the brakelight wires)
i masked the edges so if the dremel slips it doesn't mark the paint
this is the rough cut line on the inside you need to make so the spoiler will fit
this is the rough cut line on the outside edge needed for the fitment
this when the stand offs have been cut off and its rough so it needs sanding a bit to look better
these are the pieces that come off
i used some straight edge rubber molding to make the spoiler rattle go away
i added some silicone sealant to the edges so the edgeseals are firmly mounted to the spoiler
the straightedge molding i used might be a little too high profile i might trim them a little bit to get more flush fit on the bottom part
here is a comparison on the old little tiny lip vs the new type r spoiler
Driclith
Customize your car
Sep 17, 2022 06:31 AM
Rockyep2
Electrical
Jul 22, 2022 10:52 PM
Darren16
Oct 5, 2012 03:44 PM
Dan_Mac
May 3, 2010 03:04 PM
Itam
Buy, Sell, & Trade - Archive
17
Apr 15, 2005 09:11 PM
