DIY: Forgotten Tune Up Mods
Old 10-14-2009
  #61
Re: DIY: forgotten tune-up mods
TB with iac removed
and iac by itself
Old 10-14-2009
  #62
Staninator's Avatar
Staninator is an unknown quantity at this point
Kick ***! Gearbox you are holy!
Old 11-07-2009
  #63
tunedx's Avatar
tunedx is an unknown quantity at this point
I cleaned the egr valve, vtec solenoid. I couldn't remove the dam phillip screws on the iac controller. I just disconnected the coolliant lines and sprayed carb cleaner through there. All I can say is what a difference this made. Civic accelerates so much smoother. Thanks again Gearbox for the diy tuneup tips. Is there anything else I could do? I changed the evap canister and plugs already.
Old 11-07-2009
  #64
unfortunately spraying carb cleaner in coolant line holes wont help, its the other chamber you need to clean next to the coolant lines. those screws suck tho i had a hard time taking em off.
you might also want to check the front engine mount down below where the radiator is. they almost always crack. you can replace with stock or get the ES inserts to fix the stock one.
Old 11-08-2009
  #65
tunedx's Avatar
Where exactly are we talking about. Pics please?
Old 11-08-2009
  #66
for the engine mount? its in the middle of the car if you look down kinda where the header is. its a metal U on the outside and inside is some rubber stuff and usually one segment cracks. looks like #8 in front of the engine, closer to the frame of the car at the bottom.
Old 11-10-2009
  #67
tunedx's Avatar
Thanks again gearbox. I will jack the car and take a peek at the engine mount for cracks. Do u have to take it apart or can u just do a visual inspection?
Old 11-10-2009
  #68
turbo zombie's Avatar
turbo zombie is an unknown quantity at this point
for the mount labeled as 8 in the pic, you don't need to jack it up, you can look at the side of the mount (without taking it apart), from the engine bay. look at your exhaust manifold, and directly in front and below that is the mount.
Old 11-10-2009
  #69
you prolly cant see it, but you can feel it thru the middle by poking at the rubber. it has a few spokes like the pic shows, and usually one of them is torn. so if you push on it and it moves alot, its prolly bad. most ppl say they only last 10k miles before breaking due to the crappy design. but you dont have to jack the car, just stick your hand from above with hood open.
Old 11-11-2009
  #70
updated with TB-IAC cleaning.
Old 01-12-2010
  #71
king.0c's Avatar
king.0c is an unknown quantity at this point
great writeup gearbox
Old 01-13-2010
  #72
mclean987's Avatar
mclean987 is an unknown quantity at this point
TB with iac removed
and iac by itself
what kind of throttle body is that ?
Old 01-13-2010
  #73
stock d17a2 tb for auto trans
Old 01-15-2010
  #74
cb450sc's Avatar
cb450sc is an unknown quantity at this point
I finally got a chance to read through this entire thread. All great info. I've got a check engine light on my daughters 98 LX and it is supposedly the evap cannister. Is this located near the fuel tank or is it in the engine bay of this car? Is this easy to replace on this vintage?
Old 01-15-2010
  #75
should be in the engine bay, sortof near the fuel filter (#1). the canister is #11. list is around $150, you can prolly find it cheaper.
Old 01-16-2010
  #76
cb450sc's Avatar
Does the evap canister have charcoal in it or is it a paper pleated air cleaner type of can that is shown on the second page of this old thread?
Old 01-16-2010
  #77
04 Honda Civic's Avatar
I am pretty sure its charcoal in the canister.
Old 01-16-2010
  #78
the "air filter" shown earlier has nothing to do with the canister/charcoal collector. its just a plain old air filter for the evap system to draw fresh air in the system from outside. and thats in the rear of the car. maybe older civics do not even have it. the charcoal canister should have charcoal (activated carbon) and its purpose is to trap and store gas vapors so they can be burned in the engine later thru the evap system.
Old 01-30-2010
  #79
tunedx's Avatar
I performed all these steps and car runs great but noticed the other day on start up my maint. required light flashes. I have 1000km left till my oil change what could be the issue here?
Old 01-30-2010
  #80
maint reqd has nothing to do with the way the car is running. it is a mileage timer light that turns on every 10k miles by itself so you take it in for a $50-100 dealer oil change. to turn it off for another 10k miles, hold down the trip meter button in the gauge cluster, turn the key to ON position without starting engine, keep holding button for 20 seconds. then turn the key off and release button. when you turn key on next time, the light should be off.
Old 01-30-2010
  #81
tunedx's Avatar
Thanks for the tip. How many km should the timing belt be changed?
Old 01-30-2010
  #82
honda recommends 110,000 miles or 177,000 km for 01-05 civics. older civics it was 90,000 miles.
Old 02-11-2010
  #83
geetee03's Avatar
geetee03 is an unknown quantity at this point
Great thread. Looks like I'm going to be attempting the fuel filter pretty soon on a 2002 lx sedan automatic. No pics anywhere? Pics would be great!!!
Old 02-11-2010
  #84
i have not changed the fuel filter yet and you should not normally have to unless the pressure drops below spec and you have engine bogging. it is a strainer/filter inside the fuel tank/pump and quite complicated to change, so dont do it unless you have to. there are a few diy here but the pics dont work anymore.
Old 02-12-2010
  #85
geetee03's Avatar
The car shudders slightly when it is in gear while pushing the break at a standstill (drive or reverse). Anything off idle it is smooth. Also when in neutral and idling (its an auto) it is smoother than while in gear at idle.
I am going to change the sparkplugs and clean the IAC (thanks for the help there), if that doesn't fix it would it be a good idea to do the fuel filter?
The car is just shy of 100k, and has a new timing belt and drive belts (at 90k). Just changed out the alternator about a thousand miles ago.
Old 02-12-2010
  #86
i would check the fuel pressure before changing the filter. you might have a torn front engine mount also if the engine shakes more in drive than in neutral. try the iac cleaning and plugs first. the engine mount is pretty easy to check and is very easy to break.
Old 02-12-2010
  #87
geetee03's Avatar
Gotcha. Would it be worth the time to check the valve clearance?
So I'll notice a bad engine mount just by looking at it? Easy to see?
Old 02-12-2010
  #88
the mount is down near the bottom if you look in the hole between the header and battery. you prolly wont be able to see it since the mount is sideways, but you can feel around. there is always one of the two rubber legs broken. i ended up getting the energy suspension motor mount inserts which install on each side of the mount to repair it and havent had any issues. i get a tiny bit of vibration but its almost not possible to tell. the valve clearance is recommended every 100k, but again if the car is running normally, prolly isnt needed. it requires removing the valve cover and adjusting the clearance with feeler gauges to the honda recommended values. you also have to turn the engine by hand to the different positions (tdc, etc) so the valves move where they should. its more complicated than it sounds and may take a while if youve never done it.
https://www.civicforums.com/forums/1...djustment.html
Old 02-12-2010
  #89
geetee03's Avatar
A buddy and I did the timing belt and water pump ourselves, that would have been a good time to do/check the valves. We replaced the valve cover gasket so that should still be good right?
I hear a little extra noise from the motor so I will probably check them out when I do the plugs. Any feeler gauge you might recomend? Just not a cheap-o one i'm guessing.
I will report back, thanks for all the info!
Old 02-12-2010
  #90
yeah get a decent set of feeler gauges, not the autozone special. valve cover gasket if still pretty new you should be able to reuse but you may have to reapply the silicone/hondabond to the harder to seal areas.
Quick Reply: DIY: Forgotten Tune Up Mods
