DIY: Crank pulley bolt tool......$6 bucks
Old 04-13-2008
jackoncruzpr's Avatar
jackoncruzpr is an unknown quantity at this point
I found a way to make a cheap hub holder tool. I use dit on my honda this weekend with no problems. Parts to buy are as below. This work son a 01 civic with the 50MM hub hex insert.
1) 1.5 inch hex bushing from home dpot. Can be galvanized or just black metal.
2) Smallest coupling they have that is 1.5 inches.
Combine the two together and put them on tight. The hex end goes inside the hub's hex holder. Youll have to let the engine down just a bit to clear the coupling. Then you use a pipe wrench to hold it still against the lower A-arm. Use a 3/4 breaker bar with a cheater pipe and 19mm impact socket on the hub bolt and it comes off .
If you dont get the adapetr and the coupling on tight it will spin on the engine until it tightens itself up but you should be good to go.
Old 04-03-2009
amishman22's Avatar
amishman22 is on a distinguished road
Re: DIY: Crank pulley bolt tool......$6 bucks
anyone else tried? i got 2 outta my 3 pulleys on then got ****ed by the crank pulley tool problem
juror
Suspension DIY
07-30-2019 03:28 AM
OptimisticWay
46
10-15-2015 02:16 PM
WaryDriver
08-08-2015 05:08 PM
brainwashedmc
07-27-2015 10:05 PM
1khilari
07-09-2015 08:12 PM
Quick Reply: DIY: Crank pulley bolt tool......$6 bucks
