7th Gen Do It Yourself Articles Look here for anything and everything you want to do yourself for your Civic and save money! If you can't find what you were looking for here, what about writing an article yourself? Hep appreciated! Questions on how to do are better suited in the Mechanical issues section
Battery group size upgrade
Old Aug 16, 2022
Gen7Civic's Avatar
Gen7Civic is an unknown quantity at this point
I just did a battery group size upgrade for more capacity, since I use an inverter to run fridge/freezer, fans and air purifier in my camper converted civic. The original smaller battery (group 51) only had about 35 amp hours, 625CA, 500CCA, while the new (GROUP 34) optima yellow top has 55AH, 870CA, 750CCA, which is enough to last overnight with engine off and pull power. With the dual use, deep cycle yellow top battery, I can now drain the battery down to 50% without permanently damaging capacity or performance.
Old Aug 17, 2022
BrotatoChip's Avatar
Super Moderator
Re: Battery group size upgrade
You have all that in a Civic? I would be interested to see.
Old Aug 19, 2022
That7thGenGuy's Avatar
Notorious
That7thGenGuy is an unknown quantity at this point
Does it fit the battery tray? Or did you have to change/modify it?
Old Aug 30, 2022
Gen7Civic's Avatar
I did remove the battery tray, I did modify the battery securement top bracket by hammering the tab that pokes down to go against the old battery side. It's a bit of a squeeze to get the strap bolt to go in, but it does fit.
gizmo97
Oct 30, 2015 08:02 AM
eraxpres
Apr 10, 2008 02:27 PM
ty77064
Apr 30, 2007 11:31 AM
D17thgen
32
Jul 16, 2006 08:25 PM
Sim012
Nov 28, 2004 10:45 PM
