Auto X/Road Racing Auto X and Road Course Forum
pedals for heel and toe
Old Jun 14, 2005
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
does everyone use aftermarket pedals? I can heel and toe in a parking lot, but on the street, I just can't always blip the throttle b/c of the pedal spacing. I was looking at some of those $50 CF Sparcos that are on ebay a lot. I know that I want the kind that you drill into the stock pedals.
Old Jun 14, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
There's a lot of options. I'm using Momo Superturismos. I installed them favoring the left side of the gas and the right side of the brake to move them closer together, the gas also has a tab hanging off so you can catch it with your foot. I don't know if they still make them, but there must be something similar out there. OMP makes a lot of pedals in many shapes. Some of them are thin enough that you conform them to the contour of the stock pedals when you install them.
Old Jun 15, 2005
jmorris's Avatar
jmorris is an unknown quantity at this point
I still use stock pedals, but I took off the rubber on the brake and clutch and left it on the gas- it evened out pretty well. I have an older civic so the spacing may be a bit different.
Old Jun 15, 2005
Rennen's Avatar
New Mod on the Block
make sure you dont slip off the pedals.
Old Jun 15, 2005
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
there are different ways to heel-toe. u dont have to have your toes on the brake and heels on the gas. u can do the opposite. just find a way thats comfortable enough. i got enough practice the traditional japanese way so thats what i do. but i tried using the left side of my foot on the brake and the right side of the foot on the gas and that worked well too.
Old Jun 15, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
heel-toe downshifting/braking isnt always about spacing.... it takes practice.... practice around the back streets till you get it down. Eventually you'll be able to do it without thinking. good luck!
Old Jun 16, 2005
Pharoh's Avatar
Bobaganoosh!
I have this great set of Sparco's. Just blue metal full replacement jobs with the grooves and ridges on 'em. They seem to work really well.
Old Jun 24, 2005
skydog's Avatar
skydog is an unknown quantity at this point
Hey man, I think any pedal that is larger than the stock ones will help. I think the main idea here is to close up the gap between the brake and the accelerator pedals. I have foud that the offset in elevation between the pedals is pretty decent for heel-toe-ing.
I just got some cheapo universal aluminum pedals from my local car parts store, took of the stock rubber pads, and attatched them with some careful alignment (eyeball) and some flush-head self-tapping sheet metal screws. I positioned them to close the above mentioned gap, and voila, I'm Shumaker.
Old Jun 24, 2005
drjvic04's Avatar
drjvic04 is on a distinguished road
I have size 16 shoes
They seem to do the trick
Old Jun 25, 2005
Jap-Euro Fusion
I'd advise against the use of a pointed screw. I'd replace them with flat end machine screws and nylon lock nuts. Reason being if you do anything in a panic, the screws do stand the chance to snag the carpet or stick into the padding on the firewall. Neither is good.
mistahlorax13
21
Nov 18, 2015 12:47 PM
sesi
Oct 1, 2015 02:03 PM
juicetayne
Sep 30, 2015 11:02 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
speedlever
Sep 24, 2015 07:18 PM
