Auto X/Road Racing Auto X and Road Course Forum
which wheels to RACE on??
Old May 3, 2004
usafstud's Avatar
I have 5zigen Fno1r-c 15x-7, right now. I'm planning on getting a set of Rota Slipstreams 15x7.
I'm wondering which wheels i should road race/autoX with. The 5zigen's are about 14 lbs(i think) and the rota's are 12 lbs(i think).
are the strength the same on these two wheels?
Old May 3, 2004
Zzyzx's Avatar
Autocross Junky
They are both pretty tough and I believe both are race tested....
I konw the only reason Rota made the Slipstreams in 15X7 was because the autocrossers/road racers wanted it.
I'd run the lighter of the two, thats 2 LBS less rotating mass (on each whees) and unsprung weight.
Old May 3, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Which ever one you don't care if it gets trashed. The likelyhood of a 15" wheel getting smashed by a pothole is pretty low, but track curbs, on and off, and idiots running tire and balancing machines are a lot more common.
Old May 3, 2004
robbclark1's Avatar
Retired suspension supermod.
Zzyzx has a point that 2 lbs is 2 lbs, but you can also pick the ones you don't care that get trashed.
Old May 6, 2004
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
I'd say go with whichever wheel is cheaper, since the likely hood of damage to a wheel is fairly high.
Old May 6, 2004
Green Civic's Avatar
^^ I agree. The one that has less value to you or your wallet. Will the race wheel be the same as the daily driver?
Valkman
Aug 13, 2015 04:19 PM
bizspeed
Florida
Jul 14, 2015 08:40 PM
