Honda Civic power loss 02
Old Aug 31, 2018
Fivegorets's Avatar
Fivegorets is an unknown quantity at this point
Good morning! My Honda 02 has been to numerous mechanic , it’s even been to the Honda dealer.. They still can’t find out why it losses power. When driving under 49 around town it losses power . To regain power we have to floor. Recently took it back to the mechanic . Four of his mechanics look at it and they came to the conclusion it has to be the wiring . They do not know where. When my husband picked it up this morning , it started acting up right away! But as soon as the check engine light came on it ran fine. Please help us.
Old Aug 31, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: Honda Civic power loss 02
You need to tell us what the trouble codes are.
Does flooring it fix it every time?
Do you guys ever work on your own cars, and are capable of testing things? if so I'd force the car into open loop by disconnecting the o2 sensor(s), since flooring it makes it run right. this is not a fix but would narrow it down to a few sensors or the ECU itself(or the wiring connecting the two)
I'm a sign painter though, not a mechanic.so just my 2¢
you should also add your location to your profile. if you happened to be near me i would refer you to a mechanic that specializes in wiring systems. he'd probably laugh and have it fixed in under an hour
Old Aug 31, 2018
Originally Posted by Fivegorets
I had the computer changed . Mine is still doing the same thing!
I will have my husband check . We just had the ecm changed yesterday drove fine for about 15 miles , then it stared back. The check engine lights back on. But it also has a hard kick when it down shifts.
Did you never get this fixed properly?
Old Oct 17, 2018
Fivegorets's Avatar
So I was wonder if anyone knows where the timing variable soloinoid is located on a Honda Civic 02.
on a non vottec engine.
Old Oct 17, 2018
there isnt any
Old Oct 18, 2018
Fivegorets's Avatar
Thank you!
DrGottagupta
Mar 12, 2019 09:53 PM
JesusWoreNikes
May 23, 2018 07:19 PM
Lobo123
Jan 1, 2018 11:12 AM
sekhonjatt
Feb 27, 2013 10:25 PM
teampointless
Texas
Sep 13, 2004 09:49 AM
