FNG from Kansas
Old Aug 24, 2013
jeffro.tull's Avatar
Jeffro.tull
jeffro.tull is an unknown quantity at this point
FNG from Kansas
Hey guys and gals, first time Honda owner from Kansas here ( unless you count my wife, she has a 2010 civic lx). Anyways I normally drive a diesel truck but due to my recent job change which involves a 140 mile roundtrip a day commute, I decided to pick me up a cheap beat up gas getter, and what could be more reliable than a civic?
So Today I found a 98 ex coupe, 5 spd with 167k on the clock. It does not have the VTEC motor. It needs some work, it is missing the rear bumper cover, the door panels are both pretty jankity, and this thing needs to a rigorous interior cleaning, lol. But it runs out really nicely and shifts smoothly. All in all i think i got a decent deal at $1000 even if it is a bit of a fixer upper. I will not be able to pick it up till wednesday but next weekend I plan on doing a timing belt, water pump, tensioner, crank and cam seals change. I will probably also change oil, spark plugs and wires, and decide whether or not brake and power steering fluids need flushed. Anything important I need to know about these things as far as preventative maintenance, or inherent mechanical issues?
Old Aug 25, 2013
Re: FNG from Kansas
These will bend valves if the timing belt lets go, so I suggest you use factory timing components.
Factory front seals (make sure the cam seal goes in far enough)
NGK plugs
DOT3 brake fluid
Honda compatible PS fluid (it is not atf).
Suggest you change trans fluid too, Honda has their own MTF.
Coolant?
HTH
Old Aug 25, 2013
Jeffro.tull
Re: FNG from Kansas
NGK plugs
DOT3 brake fluid
Coolant?
HTH
Ok, I am assuming you want to use some time of grease for the cam seal? I am mechanically inclined, but this is my first experience with an interference motor. I will be changing whatever coolant comes out of the motor in order to do the water pump. If it fails a freeze point/ acididity test after that then I will just have to flush it. Do these have a petcock to drain the coolant on the radiator?
Old Aug 25, 2013
Re: FNG from Kansas
If the new seal doesn't already have something on it (many come with a grease on the inner lips) then I use whatever substance the seal must seal (engine oil in this case).
Outer circumference of the seal should go in dry so it doesn't pop back out.
Yes, it should.
GSRcaucAZN78
Mid Atlantic
Jun 7, 2009 11:41 AM
thebodyman
May 19, 2008 08:35 PM
